Errr one problem...u got 17's
looks like it will be the only 32gtr with bbs e-88's in au.
One more set is avail.
One more set availiable in what size and offset?
All sizes are 18" offsets and width are listed above in 1st post, if you know your 3peice wheels you can always sell the rim halves and order the desired width to make your correct offset. there is only one set available out of the 2 listed the last set left over is mine.there listed in groups of 2, one set is 4 wheels.
I need 9.5 wide et19. I am a little confused about what set you have left? I know I can order whatever lips and barrels etc (I am a bit of a bbs split rim whore - I have three sets) and I love your wheels. But if I have to order lips barrels it's adds significantly to price and makes it not viable for me. However your price is spot on given that the wheels are perfect. I would so love to see pics when fitted.
not if you sell the used lips off the wheels, if i had guaranteed interest i would sell the lips and centers separate.
On that note, 1 set of 4 left out of the 12 i have.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
