So
I own a manual 34GTT and im looking at installing tomei cams ether type B or A. My tuner has advised me they might have problems with idel due to the fact
they can't change some settings on the nistune. Which is leading me to get the type A as they are alightly smaller.
So is there anyone out there running bigger cams with a nistune and if there was any problems.
My car has 3inch exhaust, fmic, bigger injectors, 3071r and the nistune.
  • Replies 44
THis is what ive been told. Being manual we may be able to get around it. We have had some dramas with the auto cars and big cams stalling.
The problem is at 0 throttle above 800 rpm the ECU cuts the fuel. If your cams are too big and you need your idle to be 950 then you are all ready under idle when the ecu starts to add fuel again.
I would imagine the 252’s should almost idle like standard so we should be able to tune around it.
There are other plug-in ECU’s on the market but I would stick with the nistune for as long as possible
The throttle recovery is about 1800rpm with an auto Stagea image. Unless there has been a revision on Nistune that allows you to modify this setting it seems to be pretty much set in stone with this image.
I have been supplied with the wrong image for the Stagea and haven't gotten around to removing the board and getting it reflashed to the manual image. I would love to lower the throttle recovery to about 1500rpm...and get rid of a couple of error codes.
I will be fine. NIStune is alot better and alot of tuneability compared to what some tuners think, it is however alot different to most ecu's so some tuners are unfamiliar eith how to tune them correctly
That's bullshit because the decel fuel cut rpm is adjustable, and it doesn't happen when the VSS is reading zero anyway.
I would not be so sure about this.
This depends on the ECU being used.
There is not just one Nistune ECU and they all have different features depending on the hardware.
I have the Z32 ECU (Type 2) and there it seems to be working but on R34 (Neo / Type 4) I would not know.
From what the tuner said it seems he knows what he is talking about...
Best is to ask Nistune for a 2nd opinion
http://forum.nistune...+recover#p16761
Edited by Torques
Surprised no-one has asked why you'd even bother with cams on a 3071... turbo simply isn't big enough to warrant the expense IMO, far better things to spend that money on a bang for buck scale.
Im getting some great responses here keep them coming.
Johnnilicte " Replace tuner, lumpy cams don't like stoich, but being poncams man there won't be any issues"
The tuner is a very trusted and recommened on here 9/10 threads when people are chasing tuners in qld. I fully trust his addvice i just wanted to hear what others people have done in this situation.
R31 Nismoid "
Surprised no-one has asked why you'd even bother with cams on a 3071... turbo simply isn't big enough to warrant the expense IMO, far better things to spend that money on a bang for buck scale"
Thanks for the constructive criticism. What other bang for buck things would you recommend?
Half the reason i even want to do the cams is i have a weaping rocker cover seal and getting a 100k service done and the mechanic is a good mate. Just thought i might aswell get some see how the car will responsed.
34GeeTeeTee "The type B's in my car are undetectable.... Idles at 950 smooth az. They are not lumpy.
I see in your list of mods your running a Haltech. My problem is apparently the lack of ability to change a few settings with the nistune due to the higher idle. Not that they will be to lumpy.
R31 Nismoid "
Johnilicte "You're hopping to Poncams right? you didn't specify..
Poncams have very mild duration so there won't be any issues idling at stoich & stock timing "
Yer im just trying to decide between type A or B.
I think this was re-moved due to not fully working.
(See the link I posted where a tuner asked about this)
It's not set in the base-image but in the so called Address-Files (new with each SW version).
For the Z32 ECU (which I have) it is available.
I might have to retract my statement about the cut & recover being adjustable in R34 images. I can't find it in the R34 images, even though I thought I had seen there in the past.
It is there in other images I have used, like the R32 RB20.
Brakes, suspension, clutch, diff - I could go on but you get the idea :)
should not be an issue, yes the r34 nistune has less tuneable addresses than other nistune ecus it wont have an issue (most are cold enrich issues on e85 on really big horsepower setups) , i do however recommend running the std bov to help alleviate the stalling... it is an issue with some setups on r34 ecus. We have made mid 400's on r34 nistunes so they are capable, you may just need to make a few compromises.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
