Hi Every1,
Most likely a simple answer, however I've never done this before so am looking for some guidance.
I have got replacement weather strips and want to put them on. (I'm not sure if this is the correct name for them, they are the black plastic bit which goes above the side windows.
I have highlighted them in red in the attached photo. I'm not referring to the factory option weather sheilds which normally stick on top of this bit.
Wondering how these 'weather strips' are attached? Do they just clip in? Dont want to break the old ones by guessing.
Thanks in advance.
pull the door seals down/off, there is a series of about 5 or 6 screws that you undo, take off the black strip and then screw in the new weather sheild, put the door seal back on and your good to go. did them to my 34, took about 10 minutes.
Thank you mate, glad you like it.
If you want the larger version without my scribble all over it, you can get it from my flickr page below.
http://www.flickr.com/photos/82751412@N02/sets/72157631588312869/with/8008954080/
Edited by iwanta34gtr
