hi guys my 32 gtr starting creeping forward when i pulled up to an intersection when i had it n first gear and was hard to pull back into neutral when clutch was in all the way
what could the problem be and how do i diagnose whether its the slave cylinder or master cylinder ? the fluid level still seems to be pretty full .
also clutch is brand new
please pm me
thanks
As you're not loosing fluid I'd suggest adjusting your clutch pedal, check my post in the thread linked below:
http://www.skylinesaustralia.com/forums/topic/361743-clutch-pedal-at-bottom-of-travel/
yeah but it grabs normal when u let it out its like there not enough pressure holding the fork . ps it comes and goes aswell its not like this all the time it just started doing it
A few things to check before freaking out at the possible cost of a fix. Check the bedal bracket for cracks or breakage, Check the slave cylinder for travel and also bleedback/creep and check the fork, it may be flexing due to a cracked limb. If its not any of these, start saving.
