Think it's time to move on and prioritise a bit. Up for sale is my 91 model a31 cefiro. Have spent bullshit amount of time and money on this thing in the last 2 years (with receipts). I wont be letting this go for a low offer or if you seen like a dick. It was originally a rb20e non-turbo. I brought it painted, with coil overs and a stock rb25det motor and gearbox about 2 years ago. Car is mod-plated for engine and gearbox. All low ball offers or swaps will be ignored. Car is very clean for its age and draws no un-wanted attention. If you have any questions feel free to PM me. I have a shitload of receipts for this thing (15g+). The price is high but there is absolutely nothing left to do on this car, get in and drive! If you can find a better, cleaner and more reliable cefiro I suggest you buy it. If it doesnt sell Im not to worried. I may swap but ONLY for a ute and some cash. Can remove parts to make cheaper. You dont get to drive unless you put down a deposit, Im happy for all inspections and I don't mind ME driving. As stated, Price reflects how much I love this car and the time and money has been poured into. Has 6months rego. Car can be seen at matsuri.
Price: offers over 13g 6months Rego, RWC, and all spares I have.
Engine
325hp on 10 psi - 395hp on 16psi...VERY responsive setup. Have dyno sheets. Plenty left in it, tuned for fun/useable power rather then peak power
3076r .63 rear
x-force stainless highmount manifold
45mm Turbosmart hyper gate (18psi spring)
Cometic 3layer metal head gasket
ARP head studs
Every seal, gasket and belt above the block has been replaced less then 2000K's ago (half-seals, timing belt, all intake plenum seals, tapet covers, manifolds etc etc)
Custom water lines
Custom turbo lines
All new stainless 2.5" piping
Stainless screamer pipe
All new custom stainless 3" dump pipe
PWR power steering cooler with custom lines
Oil cooler with re-locator kit and custom lines
14" thermo fan on a switch
50mm Alloy radiator
Spitfire Coilpacks
Big front moount
Excedy sports ceramic clutch, rebuilt by npc rated to 550hp (not even run in)
Head was decked and cleaned when Headgasket was done
All Heater and A/C removed
780cc High-flowed injectors by 6Boost
D1 catch can
Billet radiator overflow and catch can combo
Suspension
G4 fully adjustable coilovers all round
R 180 welded diff
Adjustable castor arms
Adjustable camber arms
Adjustable toe rods
Full 5 stud conversion maintaining drum hand brake
S14 brakes
R32 rack ends
R32 tie rod ends
Power steering rack has had full recondition
Interior
All standard interior and everything works
Pioneer head unit
6” pionner speakers in front doors
Apexi oil temp and water temp gauges(in air vents)
Speco oil pressure gauge (in air vent)
Hydraulic hand-brake, sits in standard position and retains center console
R32 front seats
Monkey floor brace
Laurel floor mats for confusion..
Power Fc computer with hand controller
Deep dish steering wheel
Dilly gearknob
Cusco front and rear strut braces
Outside
Origin Roof wing painted black
33GTR wheels paints custom white (pearl white with silver flakes through it)
Car is painted a GTR grey with metallic flakes through it
215/45/17 Federal 595's Brand new!
Has 1 dint in the left rear quarter, about the size of your palm. Can get fixed for extra but hasnt worried me
New alignment
Fluids
Engine runs Royal Purple 10-40w
Gearbox only uses Redline Shockproof Lightweight gearbox oil
Will get some new pictures this week
Edited by juzz0
Looks great man, do you happen to have any footage of the car from that last pic? Also, where is the car located, and which Matsuri are you referring to?
Car is located in toowoomba, qld( about an hours west of Brisbane). Yeah there is footage. Was referring to QLD matsuri at QLD raceway 2 weekends ago. Car performed brilliantly and had no issue at all. Welcome to all inspections. Car has been my daily for the last few months and Havnt had any un-wanted attention
Edited by juzz0
  • 1 month later...
  • 2 months later...
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
