Good stuff man that's impressive, i like that you've still got the factory engine cover on that beast.
One thing i find annoying though..
SPECIFICATIONS
CAR: Infiniti V35
Gorgeous build though well done!
SPECIFICATIONS
CAR: Infiniti V35
Thx Sean,
That what I loved about HKS kit, u can still use the stock engine cover.. Lol @ Infiniti v35, it's easy to get mixed up for some people.
how many killarwasps?
I personally still not happy with the power ATM as the ECu wasnt tuned properly. The last power run I did I was only able to make just under 210kw with only upto 5000rpm due to problems with air flow sensor, 2 extra injectors from the charger,etc. now that I have fixed those little hiccups, I'll be looking at upgrading the ECu as well as 6 bigger injectors and get it re~tuned
I take it you maxed the AFM?
Go to uprev mate for ECU, forget the plug ins. They do a "bigger" AFM too that'll go into the place in the kit. Although you do have to disassemble to get to the AFM... grrrrr.
600cc inj will give you more head room than you'll ever need with 98, plus a fuel pump. Manual I take it? Should be good for 225-235kw without using dyno correction or any of that bs.
I'll be looking into that,Sam.Thx for the info on the injectors mate... I've been searching around to get a proper size of injectors and could not find it. Yes, it is a manual and I'm running wallbro fuel pump at the moment but I have my eye on aeromotive fuel pump...
  • 1 month later...
i saw this a little while ago on jdmst. nice work! similar setup to mine.
i also have HKS GTsupercharged 6mt CPV35. your power goal is definitely realistic - mine was dynoed at 234kw@rear wheels at Willall, and they are renowned for a fairly conservative power estimate. 7psi max boost and a lovely safe 10-10.5 AFR throughout the rev range.
mine is running 530cc Sard injectors though, and HKS FconV pro.
how do you find the 5zigen headers and midpipes? are you running cats?
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
    • Yeah, that and throwing away opened, part used, closed back up bottles has got to be bullshit. Brake fluid sits in not-very-well sealed master cylinder reservoirs for literal years and keeps working (albeit we know we should flush it every couple of years - it actually still works). Anything kept in a bottle in the shed with a tightly capped lid has got to be a million times better than what has been in the car for the same length of time.
    • Wait, they're claiming UNOPENED fluid has a shelf life of only 18 months?
