Hey guys, have had my r33 gts-t for 4 months with zero problems until this morn...
This morn i drove back from my nightshift and parked at the side of the house.
Left the car for 6 hrs.
This arvo jumped in to start the car and it wont.
It is cranking fine but wont start
I tried to cable jump start it but it just cranked even faster with no start.
My air con is screwed and makes a noise as I turn the key to accessories so Im unable to confirm if fuel pump is priming (althought i think i can hear it)
What should i try before calling NRMA and wasting money???? :S
Where abouts is the fuel pump located? im going to try hitting it while my cousin cranks.
Thanks alot in advance fellas
Ryan
https://www.sau.com.au/forums/topic/411835-r33-randomly-wont-start-help/
From my experience, its usually a crank angle sensor or a bad ecu that causes this when the obvious has been ruled out.
But first thing is first. You should verify you are getting optimum fuel pressure when cranking, fit a fuel pressure gauge or if you cbf unplug one of the fuel hoses after the fuel filter and see if yours squirts out when you prime it.
Also make sure none of the earth points on your car are rusted or loose.
If you turn your key slowly from 'ON' to 'Start' you will start priming the fuel pump about halfway towards start. It's easier to hear on my car cause I have an aftermarket fuel pump, but it should work if you slowly turn it till you hear the fuel pump prime then stop and hold it and it will continue priming
Unless my car is just weird :)
How long did you crank the car for? Mine sometimes randomly takes about 10 seconds of solid cranking to start for some reason. But its only once every so often and its fine before and after this
Just remember do not crank for more then 20seconds at a time and allow a good amount of time between long cranks to let the starter cool
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
