I had my RB25DET head checked and I bought another exhaust cam to replace the inlet cam so I can put adjustable camgears to my car. The cams need timing so I was wondering do I just time both cams to "stock" exhaust cam timing?
I got some specs from the tomei website and it seems inlet should be 120degrees and exhaust should be 117degrees. So should I just time both exhaust cams to 117degrees? Later I'm gonna go to a dyno to get them adjusted properly but for now I just want to get the car running safely because I'm putting in a bigger turbo and lot of other things.
https://www.sau.com.au/forums/topic/411856-timing-2-exhaust-cams/
The difference between 117 or 120 shouldnt matter, if its just to get the car running. Just be careful; always turn engine over by hand, with no compression, SLOWLY to make sure there's piston-to-valve clearance before running it. If you feel excessive resistance, stop. lol.
  • 3 weeks later...
A bit late reply but... I have a Holset hx40/35 hybrid coming to the car and I know a guy who did that and the turbo reached max power way earlier with the adjustable camgears.
Are you saying VCT is better compared to adjustable camgears that have been set up properly?
No.
VCT cannot ALWAYS compare to proper cam profiling and cam selection. But 90% of the time yes it will be better.
The engine with adjustable cam gears may have been set up for response rather than peak power though. VCT is a combination of both - response and the ability to maintain peak power due to the lobe seperation and its variable nature
Well with the camgears I was kinda hoping to sacrifice some peak power to get more response and get the max power sooner because I wanna drift the car and with the stock cams and motor the turbo probably isn't gonna start making power untill near 4000rpm
With stock cams you are wasting your time thinking about advantages and disadvantages. You are only going to get so far and VCT will be better than anything you can time on a dual adjustable setup.
Custom cams that are profiled specfically for an exact seperation etc are going to benefit from that.
I did a ca18 once. Had 2 NA exhaust cams.
It was rubbish........ Has any one thought about the cam profiling of an exhaust cam.
Are the lobes in the correct position on the camshaft to actually work effectively as an intake cam with everything set at 0?
PS........ I <3 VCT
Well damn... I'm just about to now put the engine back together so right now it would still be pretty easy to put the intake cam back to the head because the head isn't on the car yet. Well a bit annoying because I bought the cam and camgear for nothing then... haha
You bought a standard cam?
You have a Holset HX40... You will never have response with a truck turbo, so forget trying to get response by playing with things.
Go with VCT and just hope for the best IMO.
This is a holset hx40/35 hybrid made from parts from the super series and Fullrace model. I'm from Finland and around here Holset are one of the most popular turbos in here because they outspool and outpower some garrett turbos and they are cheap and reliable.
And yes I bought a standard exhaust cam used because I got it for cheap.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
