I had my RB25DET head checked and I bought another exhaust cam to replace the inlet cam so I can put adjustable camgears to my car. The cams need timing so I was wondering do I just time both cams to "stock" exhaust cam timing?
I got some specs from the tomei website and it seems inlet should be 120degrees and exhaust should be 117degrees. So should I just time both exhaust cams to 117degrees? Later I'm gonna go to a dyno to get them adjusted properly but for now I just want to get the car running safely because I'm putting in a bigger turbo and lot of other things.
https://www.sau.com.au/forums/topic/411856-timing-2-exhaust-cams/
The difference between 117 or 120 shouldnt matter, if its just to get the car running. Just be careful; always turn engine over by hand, with no compression, SLOWLY to make sure there's piston-to-valve clearance before running it. If you feel excessive resistance, stop. lol.
  • 3 weeks later...
A bit late reply but... I have a Holset hx40/35 hybrid coming to the car and I know a guy who did that and the turbo reached max power way earlier with the adjustable camgears.
Are you saying VCT is better compared to adjustable camgears that have been set up properly?
No.
VCT cannot ALWAYS compare to proper cam profiling and cam selection. But 90% of the time yes it will be better.
The engine with adjustable cam gears may have been set up for response rather than peak power though. VCT is a combination of both - response and the ability to maintain peak power due to the lobe seperation and its variable nature
Well with the camgears I was kinda hoping to sacrifice some peak power to get more response and get the max power sooner because I wanna drift the car and with the stock cams and motor the turbo probably isn't gonna start making power untill near 4000rpm
With stock cams you are wasting your time thinking about advantages and disadvantages. You are only going to get so far and VCT will be better than anything you can time on a dual adjustable setup.
Custom cams that are profiled specfically for an exact seperation etc are going to benefit from that.
I did a ca18 once. Had 2 NA exhaust cams.
It was rubbish........ Has any one thought about the cam profiling of an exhaust cam.
Are the lobes in the correct position on the camshaft to actually work effectively as an intake cam with everything set at 0?
PS........ I <3 VCT
Well damn... I'm just about to now put the engine back together so right now it would still be pretty easy to put the intake cam back to the head because the head isn't on the car yet. Well a bit annoying because I bought the cam and camgear for nothing then... haha
You bought a standard cam?
You have a Holset HX40... You will never have response with a truck turbo, so forget trying to get response by playing with things.
Go with VCT and just hope for the best IMO.
This is a holset hx40/35 hybrid made from parts from the super series and Fullrace model. I'm from Finland and around here Holset are one of the most popular turbos in here because they outspool and outpower some garrett turbos and they are cheap and reliable.
And yes I bought a standard exhaust cam used because I got it for cheap.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
