Hi Guys,
I have ordered in a HKS Super Turbo Muffler for my R34 GTR as the current exhaust, a Tomei Expreme Ti is just to loud for me as a daily driver.
It came in from RHD Japan today, I will install it tomorrow.
It is going to be really interesting to see how much quieter it is, actually the sound will be very different I guess, going from Ti to stainless.
Anyway, here are some photos.
I will add more once installed.
TOMEI EXPREME Ti
HKS SUPER TURBO
  • Like 1
https://www.sau.com.au/forums/topic/411870-hks-super-turbo-vs-tomei-expreme-ti/
The Tomei Extreme Ti looks p0rn !!! Might have to take it off your hands if you want to get rid of it for the right price :)
Well I will be happy to sell it :)
Only thing will be I have no idea who to get a shipping quote from??
But just to let you know I have one other guy from Sydney PM me last week, so he gets first dibs. I will try and get shipping quotes and let you know.
The sale thread is here:
http://www.skylinesaustralia.com/forums/topic/411047-melb-tomei-ti-expreme-cat-back-exhaust-for-bnr34-gtr/page__fromsearch__1
Good post.
My Super Turbo Muffler will go on my car tomorrow.
I ordered that ahead of the Tomei Ti for the exact reason you discovered, that the Tomei is just too noisy for what I want in a daily driver car.
Going from a more restrictive Fujitsubo Legalis R (76mm) to the 85mm HKS should hopefully gain some HP for me in any case. :-)
Good luck with your fitting!
Hi Guys,
So I fitted the new exhaust and WOW, it is SO quiet now. I can't believe how much difference it has made.
Power wise I 'think' it is OK, based on the seat of my pants there is no difference, but only time will tell - I will get it back to Racepace at some point to run it up on the dyno and just see how it goes, but I really think it is no different to the Tomei.
This makes sense to as the pipe diameter on them both are the same, no difference.
I also prefer the look of a straight exit instead of angle exit.
As per normal HKS style the quality is fantastic.
  • Like 1
Nice pics.
It's an awesome bit of kit isn't it? Very quiet (as quiet as my previous restrictive Legalis R) when idling or cruising, but makes a great sound when you give it some revs. Love it! :thumbsup:
Nice pics.
Yes,
I am very surprised at how quiet it is!! Normal driving, especially freeway driving at 100 is really close to a standard exhaust.
And then when you open it up and give it some it really starts to roar.
Can't wait to get it on the dyno and see the impact, if any,
  • 1 year later...
I'm pretty much sold on getting the Super Turbo after hearing it in real life and seeing it isn't that restrictive. Were you able to get a power figure difference between the Tomei and HKS?
Edited by choyda
The Tomei Ti is way to loud for the street and hurts your ears after a drive to and from work everyday.
The drone on the freeway sucked.
The HKS Super Turbo is awesome!!
I lost NO power at all and was making a comfortable 360rwkw at 19psi.
  • Like 1
Ah Thanks for the advice... now the decision is down to HKS Super turbo or Mines Silence-VX Pro Titan III
    • Which are almost all nonsense. Ignore. Obviously enough, if it is not a porous block, then any such thing is a waste of time. External block surface? Would be a waste of time, if the block was actually porous. It would need to go on the inside, which is inaccessible, and even if the block was open deck so that that area was acessible, it would be unlikely to work. But seeing as this is all nonsense, stop worrying about it.   If the coolant is coming from the side of the block it is 10:1 odds that it is either a welch plug, or it is coming from the head gasket. Maybe from one of the coolant lines feeding the turbo, or even the heater. Liquids that leak from up high can travel sideways along casting surfaces or pipes, etc on the engine before finding a spot from which to drop.
    • Yeah rust is sadly also a bit of an issue on my car. Doubt there is many cars out there that actually have no rust in those aeas. The strut towers look fine but some of the surounding metal sheets show a bit of brown cancer peeking out from in between. I hope I can make do with external remedies and won't have to rip open the whole front end anytime soon. It looks somewhat minor compared to some shit I have seen online. I have worked on a few cars but I expect the RB26 to be my first 'engine out' job at some point.
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
