  • 4 weeks later...
so slowly making more progress!
Got the head back and i think i twas worth the wait. little bit peeved I didn't get a flow chart or a cc measurement of the combustion chambers which i thought would be pretty standard but o well at least its done and ready to bolt on!
IT will be fun when its done but the problem is in WA no one believes in customer service or getting a job done in a timely fashion..
unfortunately no it wont be ready for race wars to much work on at the moment but funnily enough i will have all of April to get it finished so im a month to late. Shame would have been some good competition, i wanted to see if i could max the new speedo i got for it.
The head work is care of Godzilla motorsports cnc programits not cheap but its a dam sight bettter and cheaper then some hand porting jobs!
I have all my parts pretty much now so i just have to wait to get some time off work to put it all together!
stay tuned though its gonna be wild!
  • 5 months later...
hey guys havent updated this in a while thought i would put some current pictures up!
this is how she's looking at moment waiting to go to intune to get the pipe work and bits and pieces i haven't finished. Hopefully ill make it to power cruise!
  • 4 months later...
  • 1 month later...
No real update yet it's at the shop still it's almost finished! Ended up changing fuel system to run e85. See how this flex fuel thing goes!
Didn't realise how big the r type hks intercooler was till it was fitted, not a lot of clearance there!
I'll get some more pictures up shortly!
Yeh funny you should say that I had hoped to get it to racewars last year.. And here we are.
Well you will laugh at the gearbox selection.. I'm going to run the standard one at the moment. Can't make my mind up yet I was convinced a ppg rebuild would be the go but I decided if it was going to be dog box it has to be sequential but I would I was loosing sight of what the car is actually going to be used for! And that is to drive it to work everyday and the odd track day..
Simon is pushing 700whp through a standard box, however look at how he races and treats the box very gentle on the shifts and very smooth but still pretty quick shift.
he just hoards stock 32 R boxes at home.
i am chasing similar power and have opted for a 34 Getrag in my 32, slightly stronger, similar to yourself i want to keep it semi streetable so i didnt want a dog box.
Forget about a dog box for daily driving. Sequential would be a waste unless it was strictly a weekend + track car only. For 5-600rwhp the OS Giken kit or a helical PPG would be a better option. Although, the standard boxes can cop a fair amount of power.
Yeh I thought I would wait and see how long it lasts and exactly what breaks. I had thought the best option would be an os set with the billet plate and agy synchros so I'm trying to get onto the synchros at the moment and then build up the parts list from there. I've got a spare one anyways so there won't be much down time anyhow.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
