Back from painting! Few imperfections but it's certainly not a show car so nothing that can't be fixed or lived with!
Can't wait to get the engine back now and get it all back together!
Waiting on the piston coating at the moment then it can all go back together!
Nothing like a fair amount of optimism, all the best for your early Xmas present :)
They told me my Tannie and the head were out being done, so it looks like the head and drive line are under way.
But after months of having my Stroker Kit at the shop, the RB30 Block/Stroker has not been built and I would have thought that would have been the first thing completed, but I guess they do it the way they want and have a plan?
They just be waiting for a big enough gap in work to start on the engine not something you want to start stop start again. End up leaving shit at machine shops to long and going back over your work make sure everything is all done right!
What did you end up doing for the trans?
It does not really matter now but all of the parts were at the shop and it was booked in for 3 months before they said to bring it down as they were ready for it.
Drive line, coppermix Comp Spec Twin clutch & Slave cylinder, Quaife front diff, they are modifying the transfer case and have a Nismo 2-way LSD in the back.
Put Advan RS-D rims on and got some DAo8Rs tyres ready to put on. Going to use up what I have, still a heap of tread on them.
Looking at brakes and hopefully that is the end of this modifying stuff, I do not have the patients for it :)
looking forward to see what it can do with the rest of your gear, should be mad :)
I think they are putting my motor back together now. have no real idea what is happening except he asked for the Installed height , lift pressure etc for the Valve springs , so something is going on. Like a secret F**ken society :)
Looks like a Borg Worner ? Ive been hearing great things about those turbos good choice. I'll be following this thread to see what kind of power you pump out. Im about to start my RB32 and im still trying to decide out of a GTX45, 47 and a BW.
Wow a 45 or 47 haha drag monster obviously!
I've just seen on the Gtr.co page a dude has put the same combo together but is using a Vcam set up with it!
Should be a good comparison for the Vcam dam they're expensive!!
Hi Ben, was that Calibrat's build. I have been watching that and busting to see it on the go :)
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
