I'm my experience the rears are ball! If it is an NA. Hicas models used forks. The easiest way to check is to get down and have a look under the car for yourself :) it would probably take you less time to do that than read this reply :)
So if your buying coilovers you will probably be looking at ones that are reccomended for 33gtst
For a R34GTT its definately a fork type because they have the 4WS (HICAS ) like what Daniel said.I ordered mine yesterday this time from garage7 should have them by Friday. There are coilovers for GT from Justjap and they're ball type
Edited by B-rice
This.
The front struts are the same in the R33s and the R34s. On the rear the R33 and N/A R34 runs a eyelet at the bottom of the rear strut and the R33 GT-R and R34 GT-T run a fork at the bottom of the rear strut.
Plenty of different kits out there for the R33 GTS-T that will bolt in, it's now just a case of choosing the correct one for your application ;)
  • 3 weeks later...
I think its forks on the rear, but not 100% sure. What am i looking for?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
