best thing about clay is you cant do any damage, but only thing with clay is once you drop it you got to throw it away because it sticks to the dirt, get quick detailer, and put it in a seperate bottle and dilute it 50/50 with water as no need to waste 100% quick detailer
wash car, clar bar using quick detailer, then use a orbital buffer to cut,polish
then finish off with a hand wax
will come up a1
waxit.com has amazing products eg. poorboys
buffing is a whole other thread, covered allot of times, af far as clay, if you EVER hear a squeak or squeel or scrape stop because i have seen tiny grit get cought then just fark up paintworks. make sure the car is as cleas as you can get it with propper wash and shammy
Clay magic.
Waxit for cheap (SAU discount)
Carcareproducts for range.
Waxit just brought in a whole new batch of claymagic.
Dont use a quick detailer as lube, use the lubricant made for one. like one included in claymagic kit below. Generally because it contradicts to what you're doing. Quick detailers usually have a sealant in it. When claying, you're trying to remove stuff, not seal it in.
Claymagic kit: http://www.waxit.com...uemart&Itemid=1
^ Split the clay into 4. Put 3 in the sealed bag provided. and the 1 that you use, store it in sandwich ziplock bag, spray a bit of the lube inside bag when storing.
As someone said, as soon as you drop one, throw it away, or you'll just end up marring your paint.
Google two bucket wash, use ph natural shampoo, so it doesn't eat away the wax/sealant that you have already applied.
If you already have some sort of old wax, claybar can remove it, but i tend to use something like Mint APC diluted down to 1:60 (bottle recommends 1:40-80), that'll get most of the wax off without harming the paint.
Dont use any type of shammy, (well i prefer not to, especially on dark car, mainly because of marring) Get something like a waffle weave towel. Super soft, stupidly absorbent.
Oh and Clay magic (along with Dodo juice and 3M) is from japan, all the same grade of clay.
Zaino and Mint from the usa, also real good.
There are others that are real good. But i cbf thinking at this time.
Dont go for a cheapo clay, say from super cheap, they're usually a chinese poly clay, which differ in quality to above, as in, wont take off contaminates (stick to the clay/pick up), will end up dragging it along, and you end up marring your paint.
Clay magic.
perfect..thanks man
Have used clay a heap of times and never left any marks. Always do it in an up and down motion and never in circles.
Ensure you use the correct lubricant, and the more the better.
Also when storing it I usually get a small Tupperware container to keep it in, and spray some of the lube onto it to keep it moist.
50 shades of clay......lol
depending how contaminated you're paint is depends on the level clay you need - eg for a car that's sat outside most its life, living under a eucalypt, will probably need a heavier clay to really do a proper decon
but with the heavier grade clay, you'll most likely marr the paint... not a huge deal as if you're needing to use a heavy clay, you're most likely needing to polish it as well.
the finer grade clay, yes you should be able to get away without marring the paint, but it's still very easy to do if you're not checking the clay often. Something that hasn't been mentioned is that you need to constantly keep folding the clay in-on-itself so you have a fresh surface regularly.
In a pinch, you can use a pH neutral car shampoo diluted down, but some shampoos will have a greater detrimental effect on the clay bar than a dedicated lube will. personally i use FI's Clay bars... their fine grade clay is much finer than the blue clay magic.
The other really important thing to do after a claying is to give some sort of protection, wax or sealant. But you need to clean the car REALLY well after as clay residue is not going to help your LSP out at all. I use FI's Cleanse at the end (after a wash) to cut through any remaining residue, but really get all the clay residue off very thoroughly before moving onto the LSP.
Another tip is to put your piece of clay in a bowl of warm water before you start, just for a little, so it's then nice a pliable.
all this info is good, i never new how technical it can be..because i washed, clay bar with quick detailer, wash again with normal maguires shampoo. then cut and polish, then polish , then hand wax and came out absolute mint!
so maybe it can come out even better?
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
