new to this so bare with me.
Just fitted a hiflowed rb25 turbo on my near stock rb20det on my r32 yesterday with minor mods fmic bov pod 3inc, and thought it would be a good upgrade considering there seem to be rather popular but im not seeing full boost till about 4800 5000 rpm is that normal? im getting a new ecu/nistune and walbro pump fitted next week. car has no low end power just dies in the ass if i drop the revs to anything out of boost.
would like to know what you guys out there with hiflowed rb25 turbos are seeing full boost at? any comments or advice tips tricks would be most appreciated cheers.
https://www.sau.com.au/forums/topic/411894-hi-flowed-rb25-turbo-on-rb20s/
I dont have the specs on me but I Had my 33 turbo hi flowed a few years ago for my 32 and wasn't that much different then my new current td06 setup,all round- boost vs hp vs rpm range etc isn't worth it but seen as you have it already I'd try some cam gears as It picked up around 5-600rpm earlier with em..
i run a td05 and i get boost from 3000-4000 @ 1 bar
a 32 highflow comming on that late sounds odd. have you hade it tunes at all sice the new snail?
did u actually read his post at all?
#1 its a 33 hi flow
#2 his still running a stock computer - getting a nisstune soon
and yer mate from what ive read hi flow 33 turbos are pretty average on rb25's let alone an rb20... keeping in mind that 1 hiflowed 33 turbo may not be the same as the next
Have to remember an RB25 has +500cc of displacement, as well as VCT. Cam gears are a cheap mod and adjusted right can help increase response and bring that turbo on sooner without losing power
Imo, keep the 33 hiflow for the moment and as Fornoyd20 said, get cam gears and a tune - then decide. There's the potential for a gain of 5-700rpm lower boost through cam phasing and ignition timing alone. If you can get it to 'come on' around 4000rpm, that's about the point most turbo's will be doing so on an rb20.
A mate used to run a high flowed 25 turbs on his 20 and was seeing full boost way before that. Off boost driving was pretty poor but barable. A tune would help but as said it depends who high flowed it and what bearings are used, size of wheels etc etc. Tune better fuel pump and bigger injectors and decent boost control will see gains everywhere and you will be happy. The tuner will probably play with the timing anyway.
i used to run a highflow on my rb25 ( 2871, 56trim in stock housings ) , would pull hard at 2500rpm with a bar in at 3000rpm
my avcr does a brilliant job of bring on the boost, get a good boost controller and pile on some duty early in the revs.
Edited by SliverS2
What td05 is this ? 18g 16g maybe ? Just keen to know I'm thinking of putting one on my 20 And how much power is it making ?
Get a good R32 Highflow, mine is on full boost a bit after 4000rpm I think and pulls hard to the redline, right before the E85 tune was making 216rwkw with as good a response as you'll probably hope for on an RB20, drives nice off boost, remember a good tune makes all the difference.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
