Shorter cooler piping is a very marginal benefit. The idea that changing the total length of your cooler pipig will improve response or decrease "lag" in a really noticable way is a nice one to have in your mind, but that's about the extent of its connection to reality.
An increase in HP. Hmmm. Again, a nice idea, but given that it is only a handful of kW, and given that most front facing plenum designs (that replace the bottom half of the inlet manifold as well as the top) end up with shorter runners so that you actually lose some mid range, it isn't actually a big worthwhile benefit.
The only real benefits are that you get the cross over pipe away from the hot side of the engine, making it easier to fit a high mount turbo, and that you tidy up the engine bay a bit. But that tidying is really more aesthetic and provides a little better access to do work. It's not really a major improvement in how well the engine does what it is supposed to.
Sure, for trully massive HP builds, an FFP can be set up with big internal volume and so work better at full noise. But for most builds, it is barely worth the $$ and effort.
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6587523
I think it comes down to your ultimate power goal and engine bay appearance goal. We all know the appearance is important to most people just as much as power.
I have the stock plenum and it looks like arse, but my goal was a punchy reliable 400rwhp. The stock plenum will do this and more with ease. I couldn't see the point spending at least $700+ for a plenum then more for all the fidly bits people dont acount for to only gain appearance gains.
If you want engine bay your proud of then id consider Plazmaman, they look nice and are the easiest to bolt up, and from most accounts retain the most response.
If your only after say 400rwhp then spend it on something else like suspension or brakes.
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6587524
ok fair enough.
how about fmic, is it best buy a return flow kit like the ones that the piping go thought the same existing holes ?
and the a/c fan............. well i think its an a/c fan. the one that sits in front of the radiator. will that have to be removed ?
im sure their is a tread on it ? whats it called ??
cheers !
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6587665
In some respects, yes, it is better to use a turn flow cooler. That way you don't cut any holes in the inner guards. Non-original holes can get you in trouble with the defect nazis. Having said that, turn flow end tanks are probably not quite as efficient when it comes to pressure drop, and you can only fit a smaller core with turn flow than if you have straight through.
And you don't have to pull the air con fan out unless going for really thick cores.
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6587754
as gtsboy said
pretty much a waste of time unless you have done every possible thing to your engine and turbo and are trying to squeeze every little bit out of it, sounds like you aren't in that position if you don't even have a fmic yet
if you're all worried about cutting a small hole inside the engine bay for a normal fmic setup you can get a return flow cooler
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6587825
BTW, don't modify the standard plenum to move the TB, the runners are designed to receive air from top, center. If you move the throttle body to the front the air flow to each cylinder will be effected.
FFP's are nice but more or less unnecessary. I have one but its been more than a 'Bolt-on' affair. Hole cut, throttle cable mounts, extended wiring for sensors etc. Someone correct me if I'm wrong but I think you need a R33 IAC unit for most FFPs into 25neos.
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6588962
ive been looking for the same for my car,i know im not going to gain alot of hp if any,or if the shorter cooler piping will make a difference.the main reason is to tidy the engine bay up as ill be running a top mount setup and dont want pipes running all over the hot side of the engine bay. Ive been reading through many forums trying to decide what the best option for a neo would be that would require the least amount of work for it to fit. alot of people run the greddy/freddy ffp and use an adaptor plate for the iac valve,im not a big fan of this and i have only found 1 other type of ffp that is made for the neo and fits the neo iac and pretty much all the stock parts will fit. Its sold on ebay and made by a company called PnT performance in thailand, i know this is starting to sound a bit questionable but from further investigation to their ffp on 2jz's (alot of reading through supra forums) all of the buyers were happy with the product and only a minor few requiring facing.
Thats what im going for anyways,they sell for about $699+$175postage, nethless to say i am also upgrading pretty much everything else so a ffp is waranted.
Kando TD06h 60-1
Top mount manifold
Turbosmart 40mm compgate
aeroflow billet alloy fuel rail (i know its not needed,i really shouldnt be allowed ebay while drunk lol)
siemens deka 650cc injectors
1.3mm pmslr head gasket
arp head studs
tomei type a poncams (think 252 in/ex)
plus all the other little odds and ends to make the above work
Allready have nistune,splitfires,3" turbo back w/100cell metal cat and a HDi fmic.
if your only looking for around the 400rwhp mark,you shouldnt need a ffp as many people have proven in the past with much higher hp.
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6588989
Wouldn't worry about the head gasket and studs unless there is another reason for the head coming off?
I have seen the plenums you are talking about, they don't look to bad. Just remember if you have a FFP on a neo you will need a R33 TB or after market, and then if you want to retain your Nistune you will need it to have a Stagea image put into it to remove the TCS.
I have the standard plenum with a fabricated cross over pipe, not the prettiest, but i made 380rwhp @ 17psi with it, we ran out of time to push it more, but showed no signs of restricting anything.
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6589600
Not quite true. Since that was the wisdom of the time, Matt and I found a number of the DTC switches could be used to turn off the TCS stuff. I actually do not know if it will prevent the strange fuel/boost cut thingo that was happening with R34 Nistunes when at very high TP, but it would be worth a try to do it this way before going to the Stagea image.
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6589691
car was originally a non turbo auto converted to turbo manual. Never had tcs work,got rid of the tcs throttle body and have a r33 s2 which ive fitted the neo tps to. The pnt ffp use the standerd iac valve so no need to swap to an r33 item.
As for the nistune,im not sure what the boys at jaustech did when i had it installed as to what image is on it,either way it worked lol.
Im doing the head gasket as i might aswell do it now instead of it blowing later on and having to get it replaced (while most of the bits are off i might aswell replace it) studs i picked up for 200 and figured it was a worth while investment as you shouldnt reuse head bolts.
thats a nice setup neil,what turbo you have?
https://www.sau.com.au/forums/topic/411906-34-gtt-plenums/#findComment-6590311
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
