Hi guys, i have what is close to an entire stock R33 GTST available to part out.
the engine and gear box is not for sale...
Please let me know what you are interested in, make an offer and i'll probably take it :)
Here is a list to start you off:
stock rear sub frame
fuel tank
tein coilvers
entire dash
heater boc
heater fan
2x instrument clusters
front and rear stock suspension arms
all brakes and control systems
turbo from engine
plenum from engine
coilpacks
stock diff
door trims
rear seats
roof lining
AC system
complete vehicle wiring looms
hicas
and the list goes on and on....
parts are in botany near sydney airport.
here are some picks:
https://www.sau.com.au/forums/topic/411907-wrecking-r33-gtst-1995/
a bit more info:
the chassis (blue one) is my old skyline that was in an accident. that will be for sale as well eventually.
i bought a black R33 that was being rebuilt for a street car. this has been torn down and all the good bits from my old blue R33 are on the back chassis now. all the stock (mainly stock) parts from the black R33 that was being built for the street use are off and for sale. everything looks like it in really good condition. some parts i have already sold such as the R32 GTR seats that were in it.
Im not looking to spend too much time on selling these parts and shipping them around the country. if there is something you need and you live or work close by, come and see it.
let me know when and we can arrange the visit :)
If you're willing to post to Perth I would be interested in the aerial assembly in the boot if in working order. PM me if you're willing to post please. May be interested in a few other little pieces too.
HI guys, here are some updates...
all parts are pick up only from botany/marrickville
Tein HRs for sale - $500
R33 GTST Fuel tank with stock fuel pump - $200
hi, i dont have the intake pipe.
here are some more bits:
Radiator stock with shroud - $200
Stock Intercooler and some pipes - $50
HKS BOV - older style, could be copy $50
after:
front timing cover
driver side power window module
lower driver-side dash above the knee (clips intact)
plastic trim below the shifter boot
you got in good condition? in sydney as well
Edited by BWRGTR
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
