Hi Guys as topic states I have a V36 and the steering wheel surround is beginning to look very unattractive with all the peeling over time of the original rubber like paint. Those who own a V36 will know what I am talking about.
Has anyone found a solution or even better got the part number from Nissan??
Help would be appreciated.
https://www.sau.com.au/forums/topic/411911-v36-peeling-steering-wheel-solution/
I have the same issues! But if you we were to get a new part from Nissan...two years down the track the same thing will happen! So the solution that I am planning to do is either ripping all the rubber off then spray it whatever colour you want or get someone to wrap it with the 3m carbon vinyl...
only way will be to remove the steering wheel & paint it, pain in the ass taking it off.
how to take off the trim:
http://www.myg37.com...cement-diy.html
how to take off the steering wheel:
http://g35driver.com...rt-paddles.html
In the US they sell CF covers but they all have a cutout for steering wheel cruise control buttons :(.
you can wrap it yourself in CF vinyl too but I did this to my chrome door handle covers & they have started to bubble around some parts due to heat when the car is sitting in the sun, It's not really noticeable unless I point it out to people but I don't want this to happen to my steering wheel.
I plan on taking off my steering wheel in the near future when I have time & repaint the trim;
- use methylated spirit with a dishwashing sponge (the kind with the green scourer on the back) to take off the old paint
- 2 coats of primer then 3 coats of black semi-gloss paint
- I need to look into a clear coat that won't be too shiny when the sun reflects on the wheel
^ I used this same method when I repainted my R34GTt interior with great results but can't for the life of me remember the clear coat I used
this guy helped me source a new gear shifter, should be able to help you out: http://www.amayama.com/
probably your best bet, he was very helpful too
alternatively if the dealer has an up to date part system (FAST i think) you can just give them your VIN & it will bring up the whole parts listings
wouldn't surprise me if it cost silly money to get it in though
I'm painting mine because it would cost me $20 max in spray cans & will come up looking sweet :)
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
