Well it all comes down to how many extra/unusual things you want to do.  The ECU, any ECU, only has so many pins available for direct connection stuff.  So if you want to have 2x O2 sensors and multiple this and some of that and PID control of a cam position or two, you will at some point have to shunt some of it off to other interface boxes and connect that via serial comms.  If you only want to do one of those things, then, yeah, straight off the ECU shouldn't be a problem.
4 hours ago, Mick_o said:
Bout time their premium ecu done something that didn't require another additional cost or box to mount and wire up!
Correct me if im wrong but even the plug and play haltech for GTR requires an add on box for factory oxygen sensors?
Yes you’re wrong, an additional box isnt required to run any factory sensor. An extra box is required to run a wide band though
5 minutes ago, r32-25t said:
Yes you’re wrong
To add to that - this thread goes back years when someone got Vcam working on a Link without using any extra hardware, the Emtron isn't doing anything new here.  Links have been doing this kind of cam control - including on Vcam since the G4 series came out.
Edited by Lithium
I have an elite in my car and the only additional box I have is the wide band, I also have flex fuel, vcam and crank trigger running through the the elite with plenty of extra spare inputs and outputs
Not to mention you can actually can run a wideband such as an Innovate or AEM or PLX, etc.. and ditch the Haltech wideband box.
It's the misinformation and the uninformed that keep saying Haltech is shit or it needs all these boxes, etc.
Yes the Haltech Platinum Pro may have needed a box if you needed more inputs - however most didn't realise you could get away with just the auxiliary harness and skip the I/O box. Also yes Haltech E6X and E8X were hated upon many tuners, but that was over a decade ago - Haltech has come a very long way since then so tuners who tell customer they charge a Haltech tax should really be reassessing what they're saying.
The Elite series addresses all the short comings the older generations of the Haltechs had. Not to mention their tuning SW GUI is very intuitive and easy on the eyes. FWIW, I don't even own a Haltech myself, I just install/tune them on mate's car.
  • Like 1
  • 6 months later...
I had the 2500 Elite Pro to run the Vcam , to replace the Haltech R34GTR Platinum Pro as  would not do the what I was going to do with my car without add ons , sold them and put the Emtron KV8 in. :)
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
