Has anyone thought about the tuning issues with running screamer vs plumbed back waste gate pipe?
Obviously exhaust gas is being vented to atmosphere with a screamer, exhaust gas contains unburnt fuel, so would that mean that the O2 sensor is getting an incorrect reading in terms or rich or leanness of the tune because it is only seeing say 80% of the true exhaust gas?
This could also play a part in plumbed back systems which enter back into the exhaust after the position of the O2 sensor, which also isnt seeing the correct AFR readings. Obviously most tuners place a wide-band up the rear of the exhaust to tune, but if we are running factory ECU (with Nistune) which uses the factory O2 sensor could this create lean/rich conditions?
So my thought was, to have the waste gate pipe plumbed back into the front pipe, and have the O2 sensor moved from the factory position (5-6 inches from the Turbo) to somewhere just before the cat.
My thoughts: it doesnt matter whether 20% or 50% of the air is unseen by the O2 sensor, the RATIO of the air to fuel (afr) remaibs the same of the escaped exhaust gas after it leaves the manifold, so regardless of the QUANTITY of gas goin thru the sensor its still measuring the correct afr.. Please correct me if weong?
02 feedback is only used on cruise when gate is shut.
Under load 02 is ignored
So its using AFM voltages yeah? Would explain alot then lol
This makes sense, but what if the waste gate wasn't mounted centrally (in my case) on the manifold and the cylinders closest ran leaner/richer then the rest. But I think above is on the mark.
You sir are correct. You get a gold star :)
Kane u seem to be getting confused.
The wastegate doesnt bypass unburnt fuel etc it just bypasses amount of exhaust gas.
Ron is 110% correct saying it doesnt matter how much exhaust gas is bypassed it still has the same exhaust gas crom te screamer as the tailpipe
    • What wires were for the revers light
    • One thing that I will miss when I retire from full time is my access to the laboratory ovens at work we use for soils testing  Jackie has forbade me from using the oven at home for curing paint...LOL The paint on the NC's OEM "strut" brace thingo was a little off, so some prep and some gloss black "Raptor" wheel paint I had left over made them all pretty again, the parts will sit in there overnight at 30°c and be ready to reinstall  tomorrow
    • Just had a chance to have a read of this, exactly the type of info I was after thanks for that! Amazing that thread never showed up in search   Yeah I'm definitely getting swayed away from the solid conversion, plenty of people getting impressive results without it
    • The funny part is, an engineer's cert still doesn't actually make the car legal. Interesting part on that IE, even some cars from the factory are defectable as they sit in the showroom. So even stock doesn't mean legal.
    • as hydro lifters/ head will do 450kw no probs - went through many race engines at that power and 7.5 - 8 K rpm and the head was never the problem  especially if a street car you not going to push it hard enough consistently enough either solid lifter conversion is big $$ not $600 - $800, do this and that and put em in I know someone doing nearly 800kw on poncams 😉  well a few tbh
