It is recommended that if you have to use the spare, put it on the front.
Less chance of damaging driveline due to the front diff being an open differential, so wheels can freely spin at different speeds.
If you put it on the back, you'll probably burn out the plates in the limited slip diff...
So if you've got a puncture on the rear, put up with the fact that you'll look totally stupid putting the spare on the front first to get that front wheel; attracting comments like, "Oh look at the 2 digit IQ mechanic! He's replacing a totally good wheel with a spare & he doesn't even realise he's got a flat at the back!" > guffaws
80 Km/hr speed limit on the spare BTW and you may feel the car brake (or steer) slightly to one side
Guess if u had a flat in the rear, put good tyre from the front to the back, then spare at front
Would be abit annoying changing 2 tyres on the side of the road :(
I considered doing it once, then remembered I had RACQ (Queensland road assist), poor fella.
I always assumed two proper wheels on the front would be beneficial somehow, also my front brakes don't allow for the spare to fit over the caliper.
