Just an EOI ATM
Looking at selling my white r33 s1.5 m-spec
S2 Rb25det 155thou
Manual
19" black rims with chrome dish
Greedy Profec - b spec II
Greedy auto timer
Front mount intercooler
3"( I think ) kakimoto exhaust with cannon
Dual port BOV full legal
Custom intake pipe to K&N filter
Filter shield
KAAZ locked diff
Lowered on bilstein shocks n springs
Trial front bar with after market grill
M-spec skirts
Rear pods
Genuine GTR wing
Alpine single din media station
Clarion 6" splits x-overs an tweeters
Clarion 6" rears
Clarion 4 channel amp
Blue dash lights
S2 cluster cover
Coloured coated dash fashia dark red velour
Aftermarket steering wheel with boss kit
2x 60mm DRIFT gauges in a dual greedy gauge holder ( boost/oil pres) oil pressure not connected lights up but not connected
Rego until 31st may 2013
Never been in an accident
turns heads everywhere I drive
Sounds awesome an a very unique flutter
Bad points
Sits low at front scrubs alil on full lock
Couple of paint chips on bonnet/ A pillar / p/door
All getting touched up on Monday
Hole in carpet where my heel goes but has floor mats now so u dnt see it
Couple of scratches on rims
Car is located Richmond NSW
Chasing $8,000 no stupid offers
No test pilots/wanna be stunt drivers/ n no s*** talkers or time wasters
I'm happy to take you around the block whilst I'm driving that's all
pm if genuinely interested
Rear pods will be put back on Monday freshly painted
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=400650
Edited by FR33ZN
https://www.sau.com.au/forums/topic/411970-eoi-1995-r33-gts-t-m-spec/
The steering wheel is Nardi also has white Nismo side indicators
Recently full serviced runs awesome
Boost controller isn't tuned yet but I had a play around with it running 10-11psi get it dyno tuned n will run mad I'm happy with how it runs now though
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
