Hey everyone, I recently noticed my gtr would blow a heap of white smoke just after I've warmed it up, so I figured I'd check the coolant and oil. The oil was about half and the coolant was pretty much gunk from the missing oil. So I did a few searches and it turns out that there is a few possible causes, 1. Blown head gasket, 2. Stock oil cooler has failed and either a cracked block or head. Just wondering if anyone who be able to help me out by leading me in the right direction.
The motor is only freshly built with forgies, acl bearings, n1 pumps and a cometic mls head gasket sprayed with some head gasket spray( I forget the name of it but my mate who's a diesel mech said it would be a good idea to be safe). It wasn't smoking until about 3 days ago and oil pres looks fine on a auto meter gauge and I haven't over heated the motor at all, it's always been at half way on the gauge. Although I have upped the boost to 14psi on the od occasion. So I'm kinda stump to what it it could be.
https://www.sau.com.au/forums/topic/411978-rb26-oil-in-coolant/
Did you use arp head studs on your new motor?
It's a must with big power 26's. Especially if you didn't face the head or block.
I'd say head gasket failure. Do compression test and go from there. Good luck
Seeing as you recon blowing white smoke.
pull spark plugs you could find the problem.
you may find crap in a cylinder, sure sign head gasket.
but a blown head gasket doesn't always leak into cylinders.
oil in water is oil gallery to water path, proberly head gasket.
as for the special sealant guess that's not working hay.
why was a sealant recommended for head gasket, what was it supposed to do / help / fix ?.
My monies on cracked block if its got ARP head stud kit, or porrus holes in bores. Have a look at the block on the exhaust side were the oil feed banjo bolt goes into block... look for coolant stains (white-ish green) As someone else also suggested remove ALL spark plugs and if have access to bore scope is best to look inside, if not look for odd coloring on plugs. make sure you keep plugs matched to cylinders so you know were to look once you strip down engine. Hate to bearer of bad news bad you will be at best taking the head off. Ive never seen an OEM heat exchanger leak,crack,fail in 15 years of doing GTRs...
The motor is about 1500km old, I had the block resurfaced but not the head, I just used the stock head studs and yeah it was the hylomar stuff we used just incase the head was warped.
Like Dan said, they say on the install instructions not to use hylomar or similar as there is already a coating on the gasket. Also the finish on the deck should be ok but if the head wasn't skimmed it might not be a fine enough finish for the use of a MLS gasket? (cometic recommend a 50ra finish, but I have no idea how to measure that). And if the head might have been warped (in which case i wouldn't think standard head bolts and a metal HG are going to be the best option..) then the best way to ensure it isn't is to measure it and get a truing cut if you need so you don't have to pull it apart to do it again, which is what you're going to need to do unfortunately
Edited by doo doo
Is the old skool straight edge + feeler gauges check worthwhile doing first, rather than going straight to getting it skimmed?
Yeah, that's what I meant by getting it measured, no need to skim if in spec. But would still be looking at the surface finish when using a metal HG too, maybe stock finish is ok.
Were the head bolts you used new, were they tensioned up to the right torque in the right order according to the workshop manual?
It would have been a good idea to skim the head warped or not, for $80-100 it's worth knowing your head is flat and has a good surface finish for sealing.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
