Alvin my mate told me he saw someone reverse into you when you were leaving lol
How bad is the damage?
actually i've forgotten about that already. yeah, that pulsar guy with RE stickers. reversed, bump, then sped off.
must be those plates. LOL.
  • Replies 254
How long have I known you for Laith..? Yes it's Jamie :laugh:
Yeah you can use the pic.
Thanks.
I have a hell of a time remembering names. I remember faces, but have always had trouble with names. Add forum names and I'm screwed. >_<
You mean Leroy Peterson (sp?) from the forums in the Silver Pular SSS?
Edit: Sunkist man beat me to it
Thanks.
My names actually (OO)SKYLINE(OO) but I just introduce myself as Jamie...
Damn all this time I've been calling you "Bracket zero zero bracket skyline bracket zero zero bracket"
And you've never corrected me
Wow so many nice cars! Love the GTR's. THe Blue r34 gtr with white rims and the Silver r34 gtr was off tap!
Spewin I came abit late. Thanks for the pics of my black r34 guys.
cheers.
Great pics guys, keep them coming
Who had the slammed black 34 with black rims? More pics of that please!
Lol Thats mine, i came late. Spewin would of got more shots. But i think there should be more of mine.
i saw a few people taking snaps of it.
thanks guys.
^^ All good Tav!
they're actually Os not 0s
I thought it was Jackie chan
dat me indian guy.
:rofl:
oh shit man! sorry! had no idea. Guy in a mini in the other lane was pretty close and givin me a greasy for swinging wide, so backed up, thought it was just the gutter.
PM me
Also worth mentioning that I noticed when I got home that both my reverse lights have gone :S
This is another thank you message to the organizers..... Although I rocked up with Sunkist, KyuubiGTR and the m3 at 9:30 and got kicked out of every place we thought it was being held.... But other than that it was sweet. Even got interviewed for sau tv. Cheers fellas and a big that u to Sunkist for supplying Sunkist out of his own pocket
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
