Its time to sell her, I am only selling her because im looking to buy a house or start my own business up.
Im in SA
She has done 68,xxxkm
Engine
Garrett 28/60-7 (only 10,000 km old)
Port matched turbo manifolds
ATI 1000hp Balancer
Sard Twin Entry Fuel Rail (500km old)
Sard 800cc Injectors (500km old)
Nismo Air Flow Meters (500km old)
Nismo Thermostat
Greddy intake piping
apexi pods
260 Tomei cams
Greddy adjustable Cam gears
Nismo engine mounts
Oil Catch Can
Full stainless steel 3.5" exhaust
Splitfire coilpacks
Huge Intercooler 100mm thick
Apexi Power FC and Hand Controller
New Xtreme Clutch ( only just put in )
Lightened Flywheel
Braking and Suspension
HKS Coilover Suspension all round
Standard Brembo brakes
Cusco Front and Rear sway Bars
Interior
Standard GTR bucket seats
Nismo 320km/h speedo
Nismo Floor Mats
Nismo Gear shifter
Alpine Head unit
DLS 6.5” front and rear
DLS AMP
DLS Sub
Cheetah Alarm
Exterior
Z-Tune Front Guards (Genuine Nismo)
Z-Tune Front Bumper (Genuine Nismo)
Z-Tune Side Skirts (Genuine Nismo)
Z-Tune Rear Pods (Genuine Nismo)
Z-Tune Rear Wheel Arch Flares (Genuine Nismo)
Z-Tune Style CF Bonnet
Nismo CF door pillar garnishes
Night Pager Wing Extensions
Carbon Fibre rear diffuser
Carbon Fibre Front diffuser
Rays/Nismo LMGT4 18x9
I have probably forgotten a few things but I think that's it.
It makes 275AWKW on 10.5psi. The only thing the car needs is a boost controller to easily make 330 -340 AWKW. Comes with books and receipts as well from previous owner.
The paint is perfect
The edge of the screen has a small hair line crack in it as seen in the photo.
It has had minor front damage (in Japan) but nothing serious, i have had the car checked over. Shaun From boostworx has serviced and checked over the car, any questions please give him a call
on (08) 8260 5566
Any other Questions please don't hesitate to call me 0403894492
Please no dreamers or tyre kickers, i will be the only one driving the car usless deposit has been put down
$52,500ono
Photos
Edited by Alex_23
  • Like 1
https://www.sau.com.au/forums/topic/412021-fs-1999-r34-gtr-v-spec/
  • 3 weeks later...
  • 5 weeks later...
Hi Alex,
Beautiful car. Just a few questions, does it come with / do you have the stock bonnet or was this part of the accident replacement?
Hi Alex,
Hi Chris
i dont have the stock bonnet and im not sure if it was in the accident replacement or it was bought and just swap out.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
