Hey guys, I just swapped out my turbotech bleed valve for a blitz dual solenoid ebc spec R
Everything is working as it should, except, i am up to 96 on the boost control.
The boost control goes from 0-100 so its nearly maxed out.
At the 96 setting its sitting on 1.3 bar quite consistantly, I really want to be able to use over 20psi, or 1.5-1.6 bar.
The way its looking it will only go to 1.35 bar max at 100 set point.
car is R32 gtr
stock engine
jun 264 9.7's
-5 turbos with stock 14 psi actuators
Hpi dumps
twin 3" into full 4" system, no cat, one straight through muffler/cannon
With the Turbotech setup i did have boost above 25psi for a while, so the turbos and support gear are fine.
Anyone else experienced this problem?
nope, ive had a far play about with it. i have adjusted the gain up to 27 at the moment without any spiking.
the boost setup on the controller was on 50 when i started playing with it and was only running actuator pressure, 13-14 psi.
so ive been adjusting the setting from there up to 96.
but strange, like its run out of range.
i was thinking some different actuators would help, but i would think this unit would do better than this :unsure:
I just went out for another drive, set to 0 (zero) boost is .93 bar, spot on each time. Which I'll assume is wastegate pressure.
Turning the controller up 10% at at time, 10, 20, 30, 40 about when I get to 47 the boost changes to .95bar.
And I continued tonight to set it to 100 (max) and I have 1.32 bar.
Checked lines under the bonnet. It really is piss easy, 'in' is where the manifold pressure goes, it's connected to the plenum b4 the throttle body's.
'out' goes to the two internal gates on the turbos actuators.
Any help appreciated.......
At 100% duty cycle, you should see unlimited boost as the mac valve would effectively be bleeding all the air. Just to confirm you have a manifold pressure line connected, a wastegate line connected, and 1 port on the solenoid not hooked up to anything?
if your not having any luck, screw in some more preload on the actuators. With it dialed all the way in it should give you 19psi gate pressure and shit load more response. Then 25psi will be a piece of cake, all depends on how much minimum boost you want to run though. My spec r also doesnt make any changes from base pressure until 40+.
The unit only has 2 ports, one marked 'in' and one marked 'out'
Not sure where the air is bleeding out, there is not another port or hole. Bit strange really.
When I have the boost set a bit lower I can hear the valve fluttering and doing its thing. So it works.... Kinda. Lol
Good to hear, im not the only one then, yours sounds like it does something similar. I adjusted the wastegates to have a bit of preload, looked it up on sau, they have been like it for the past year.
So you get 19psi out of the stock actuators just with more preload? More preload means the wastegate flap cannot open as far, so giving worse control over boost pressure too yea??
Im guessing u installed the controller at the stock boost solenoid hoses? This doesnt work, well hasnt for me anyway, i had to change to a different pressure source to get it to work as the stock pressure source is connected to the bov plumback or something stoopid,
When I installed my EBC, the workshop had to run a new manifold source line as DVS has said, the stock line doesn't work (the source is already bled, clutch line iirc)
Checked the lines tonight, one straight from under the plenum to the solenoid
and the other comes from the actuators around the back of the motor in the hard lines to the solenoid, there is one "T" in the hard line which i have blocked off.
So the lines seem fine. :dry:
I do have the solenoid mounted where the stock solenoid use to live on the drivers side, perhaps it need to be closer to the turbos? Its a bit shit to have to move it now as i have run the cables in the guards and all.
Also i figure its best for it as it will get hotter on the passenger side of the engine bay, thats if i can find anywhere it will fit........
Lets say i looked into getting some different actuators anyway, where have people bought theirs from, I can only really find actuators that are 1 bar or a HD HKS ones, Can 18 or 19 or 20 psi actuators be bought off the shelf?
Electronic Boost controllers do not bleed, they simply supply pressure to the actuator in a normal situation or block it when energized. At 100% duty there is supposed to be no pressure going to the actuator at all so you lose all control and run "max boost". Now mac valves work pretty much the same, only it has a third port that that vents the pressure, as oppose to pressure going no where when solenoid is energized either way they work the same.I am a bit baffled why your car can make the boost on the turbo tech but not on the solenoid, either the blitz is incapable of running that much boost or when you switched controllers you coincidentally introduced some boost leaks to the system (intercooler pipes etc...).
There is no off shelf actuators stiffer then 14psi, however if you shorten the rod (10mm) like i told you you'll get up to 19psi out of it. This will not cause an overboost it is doing the exact same thing your boost controller is attempting to do only its doing it mechanically and a lot better. The advantage is with this much tension on the actuator, there is no creeping and boost builds faster and harder then any electronic controller can attempt to. Downside is your minimum boost has been raised, so there is no real safety boost any more. I personally ran 8mm (10 full turns) preload on my car which is 17.5psi, just make sure you do them both even and switch your boost controller to 0 before you go for a drive it will only take you 5minutes to do this so give it a crack. With this much tension from the spring its hard to attatch the rod to the wastegate, so use an air compressor or air pump to help.
If it's a blocking type solenoid, then I think it's either faulty at the controller (not sending the right signal) or faulty at the solenoid (range of movement, it's not blocking the line completely)
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
