Hey all,
I have a fair amount of R32 GTR gear in my house that I no longer need so want to try and get rid of it all. All prices are just a rough estimate and I am negotiable on all of them so make me sensible offer and I will probably say yes.
I don’t mind posting the smaller stuff (at the buyers expense) but some of the bigger/heavier items I would rather have picked up. Need this stuff gone a.s.a.p. so will be very negotiable on prices.
  1. Standard R32 GTR fuel pump. In perfect working order when removed. $40
  2. Random pipes and hoses $25 for the lot. Or I will just through them in the bin…
  3. Downpipe, unknown make or age. Slightly damaged (see pic) $100
  4. Standard R32 GTR injectors. $65
  5. Standard R32 GTR ECU. $125
  6. Dead RB26DETT Engine, not sure what damage is done but the oil pump broke and probably seized the engine. Don’t have the time and can’t be bothered taking it apart to look, just want rid of it. Comes pretty much complete from sump to covers (including standard turbos)… $1750
  7. Apexi Power FC with hand controller. Bought but never fitted. $900
  8. Bee*R Rev limiter. Brand new, bought but never fitted. $200
  9. Brand new in box Gates racing timing belt to suit RB26 $100
  10. OEM 3D Carbon Fibre Vinyl Wrap 1520mm x 5000mm $75
I will get pictures uploaded later today hopefully.
If I find anything else I will add it on. Can get hold of me on 0406188865 or send me a message on here.
Thanks
https://www.sau.com.au/forums/topic/412059-r32-gtr-parts/
  • Standard R32 GTR fuel pump. In perfect working order when removed. $40
  • Random pipes and hoses $25 for the lot. Or I will just through them in the bin…
  • Downpipe, unknown make or age. Slightly damaged (see pic) $100
  • Standard R32 GTR injectors. $65
  • Standard R32 GTR ECU. $125
  • Dead RB26DETT Engine, not sure what damage is done but the oil pump broke and probably seized the engine. Don’t have the time and can’t be bothered taking it apart to look, just want rid of it. Comes pretty much complete from sump to covers (including standard turbos)… $1750
  • Apexi Power FC with hand controller. Bought but never fitted. $900
  • Bee*R Rev limiter. Brand new, bought but never fitted. $200 SOLD
  • Brand new in box Gates racing timing belt to suit RB26 $100
  • OEM 3D Carbon Fibre Vinyl Wrap 1520mm x 5000mm $75
https://www.sau.com.au/forums/topic/412059-r32-gtr-parts/#findComment-6589505
  • Standard R32 GTR fuel pump. In perfect working order when removed. $40 SOLD
  • Standard R32 GTR injectors. $65 SOLD
  • Adjustable Cam gears to suit RB26 $70
https://www.sau.com.au/forums/topic/412059-r32-gtr-parts/#findComment-6592552
Price Dropped:
  • Downpipe, unknown make or age. Slightly damaged (see pic) $50 (collect only)
  • Standard R32 GTR injectors. $65SOLD
  • Standard R32 GTR ECU. $100
  • Dead RB26DETT Engine, not sure what damage is done but the oil pump broke and probably seized the engine. Don’t have the time and can’t be bothered taking it apart to look, just want rid of it. Comes pretty much complete from sump to covers (including standard turbos)… $1500
  • Brand new in box Gates racing timing belt to suit RB26 $75
  • OEM 3D Carbon Fibre Vinyl Wrap 1520mm x 5000mm $50
https://www.sau.com.au/forums/topic/412059-r32-gtr-parts/#findComment-6594206
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
