Wow, if they manage to find out who did this, goodness me.
$10 bux says it's a local, probably an Otford local. Woman, 45ish, I reckon she lives near that viewing spot there, where you can see down the coast. She is recently divorced, she has a part time job in Engadine to which she catches the train and she is pretty soon about to have quite an extensive collection of used, worn out automatic transmissions and transmission casings.
Bullshit aside, it was most likely someone who has been activated (driven to action) by hysterical Today Tonight/ACA coverage of "hoons", particularly in the NP, putting oil on the road is, to me, akin to tying fishing line neck height between two trees on a trail up the bush because you don't like the pushie riders who go up there, if they find this person, I hope they are bought before a court to face some serious charges.
  • Replies 46
Perhaps it could be a conspiracy! Cops working with ACA to spill oil on the roads and have us and other JDM cars, slide right off the road, crash and get accused for drifting at the corner, ACA writes mad hoon story for dinner and makes billions from prime time advertising, car "enthusiasts" gets accused and a green light for investing our hard earned tax money into more defect stations, car crushers, patrols etc, and thus increases state revenue in which pays for their wages, in which again gets more cops and fines on the road which ultimately increases the governments money, and finally ends up in the pockets of missy G (J.Gillard) to pay her own carbon tax bills, in which goes back in her pockets anyway.
Wouldn't be surprised if ASIO agents start tapping my wires now..
Not a tax. Price. And she doesn't pay it. Top polluters.
Not sure why I'm bothering though - nobody seems to have EVER heard the full quote, nor read as to who is actually paying the carbon price.
It seems I am paying for it according to my electricity bill
Foil hat time anyone lol?
That and te whole car crushing thing has recently had a single case put through te courts and won, as a violation of our rights. (and te forced forfeiture of the cars from "hooning") and now there will probably start to be a land slide of cases for damages caused by the state.
They're just waiting to see if the gumbyment appeals the last court order or not. But this case will set a precedence.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
