In the mean time I have been busy starting to do the suspension mods needed for the track. More on the way but here is a start.
Pulled out the entire HICAS system and replaced the power steering pump and reservoir with one from a R33 GTR. Also managed to pull out the all the air con, for more weight saving and then installed;
Hicas Lock Bar
Subframe Aluminium Lock Bushes
Cusco Castor Rods
Solid Steering Rack Spacer
New front brakes are on, CSC 4-piston calipers with 343x32mm 2 piece rotors
Behind the new wheels which are Enkei NT03 18x10+18 all around
Cusco front Castor rods and swaybar done
Cusco rear swaybar in and HICAS lock bar installed
and UAS pivoting front camber arms are good to go
Edited by SimonR32
Makes me want a 32 GTR even more now.
Nice buy. Needs P1s, or I refuse to believe this is your car.
Well I do need a set of 17" wheels with good brake clearance for the track haha
Apparently I'm banned from getting another set though, looking at a set of RPF1 17x9.5 +18 for now... Just need to check clearance first
Edited by SimonR32
Good stuff ... love the detail on getting it to turn corners and stop!!
You've done this before??
It's my 4th R32 so I guess I've done it all before :)
Went from
R32 Gts-t RB20
R32 GTR RB26
R32 Gts-t RB25
to this R32 GTR
Hence the final build... Damn things send me broke :whistling:
