Shiite - impressive times! I was hoping to see it run in anger that day but boredom won out :P
Guessing that makes you one of the fastest guys around Barb's now (excluding the dedicated race cars that is)?
Yeah I think I went back out as soon as you left haha
Short track I'm still slower than Chris's old FANTA 32R and Gav Beer but long track I don't know of anyone who has gone faster without a stripped out caged race car?!?
Competed in the WASCC LF Speed Event Series at Barbagallo Long Track on Saturday. Went 61.80 on the long track which I still can hardly believe. Got the class win and came 4th overall, only being beaten by 2 open wheelers on slicks and a fiberglass 950kg 180sx with a Chev V8 and slicks.
We are trying to work out if it's right but we are fairly sure I'm now the fastest street car (interior, full glass and no cage) around the track. There are a few cars that are quicker on r-comps but they are all stripped out race cars.
Haha!
That is freaking awesome, congrats dude!
950kg V8 180sx.. Wow.
Got a new set of wheels for it because I'm (and the people who are doing it) are getting sick of swapping between R-comps and normal tyres all the time. Will be using these ones at powercruise and racewars etc.
Origin DNA-02 18x9.5 +15
Looking good. Can't believe you were changing tyres on the same set of rims for every event!
What's next to make it quicker or are you satisfied beating everyone as is :P
I pulled off the R-comps yesterday and the front left was fairly shagged so maybe a rotation might give me some more grip for a faster lap time :) I'm so slack that I hadn't even touched the car between the last 2 events for that tyre has done a shit load of laps on the loaded corner haha
Apart from that, I'm trying to build this new house so I'm going to keep spending at maintenance for now.
Got a new radiator on the weekend. Temps were getting up to and above 100 so hopefully it will help
Edited by SimonR32
  • 5 weeks later...
Koyo rad is installed and I've been playing around with the oiling system to try and alleviate the oil building up in the catch can at the track.
Been thinking about a lot of different options (without pulling out the engine) and came up with the following
  • Rear turbo oil drain connected by dash 10 line to the rear cam cover fitting to vent the crankcase
  • Dipstick has a dash 8 line to a fitting welded onto the catch can to vent the crankcase
The theory is that the crankcase being pressurised is stopping the factory oil drains from working correctly, these vents (should) release that pressure allowing for oil to flow back faster and thus not getting stuck in the head and pushed into the catch can. Fingers crossed it works ;)
When I take my car for a belt I do the dipstick mod too. Does help and easy to swap over.
Hopefully will help me as well! How do you seal the line over the dipstick, simple hose clamp?
I have no issues in a straight line (even 0-1000m drags), on the dyno or on the road but at the track it does get close to out of control.
  • 4 weeks later...
Another Speed Event Series and I managed to break my own lap record again and win the class so happy days... My oil solution didn't work so back to the drawing board :(
Also finally remember to weigh the thing and it's this much without driver and 1/3 of a tank. Not light but not the worst for a GTR in full trim
  • 3 weeks later...
You car has come out mint, looks damn fast too, good all rounder, the best kind.
couple of questions for you if you have a minute to answer, your Cusco and UAS adjustable arms, how much noisier are they than stock rubber bushes, as in knocking, clunking, NHV etc. I'm kind of hoping that quality bits like Cusco wil be better, but even a quality spherical bearing joint must be noisier?
Also, i have the same Trust sump extension on my car, do you have aftermarket baffling or just the stock windage tray etc. with the extension welded on?
do you care to share your wheel alignment specs :D
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
