To put it simply, bigger A/R = more flow and more power but at the cost of response/more lag. A smaller A/R turbine will spool a turbo quicker but at the cost of power. Matching a turbine A/R will most depend on the flow of the engine (size) and power target.
I was thinking of going for the 0.87 :) . Would love to try a 1.12 a/r but maybe 2 laggy but would have nice power, i think :aroused: .
Im no expert but id estimate that the .87 housing would probably suit you the best...the 1.12 would be too big and .69 would strangle top end and probably come on boost to hard.
On a Rb25 with a 0.87 would the spoolup will be 2 quick or is the 1.12 better so its a big laggier and more power?
Umm.. RB25? going by your sig
* RB30DET on its way
So why even think about an RB25? Or are you dreaming of the RB30?
If u want good power and response then piss off the 1970's TO4E and get a twin ball beaing turbo. As an example my GT30 with 0.82 a/r rear power comes on hard at around 4000rpm (1 bar).
:werd:
mine comes in at like 4200... pretty much the same as you Denham.
love it :)
Response and lag depend on alot of things.
Dont be too quick to think a BB turbo will outperform a bush bearing. Point in note T518Z, which can make 1 bar under 3500rpm on a 2L bottom end (SR20). Older bush bearing turbos though - just dont expect anywhere near the response as from a newer turbo.
With a GT30, I am getting 1.2bar at 4000rpm with 0.87 housing. It was not always that good, I had to sort out my exhaust and a few other bits (eg PCV valve) to get it there. I have since been told that by a Japanese mechanic and pro D1 driver, that he believes the turbo is capable of coming on boost earlier, and making more power than it does. He puts this down to tune.
Tune can make a huge difference to how a turbo comes on. Judd has bought a Jap trained mechanic over to do some tuning, and in one case, brought boost on 800 odd rpm earlier by tweaking the ecu, with a drop in detonation. Tuning can make or brake a combination, as can any other weak link in the chain.
The Jap mechanic I spoke to said he likes to tune around 11 AF ratios, and use timing to get response. This seems to be very different to what most seem to do in Aust (that I have had experience with). They tune for top power, at around 12 AF ratios.
I originally started with a 0.61 turbine AR, this was way too small for the street and resulted on boost coming in so hard that the car would step sideways at around 3000rpm even with light throttle, in 4th gear. Not good when you are travelling at 100kph in traffic.
As a result I could only use low (1 bar) boost on the street, and a tune of around 256rwkw. Now with a 0.87, it is possible to use the right foot to control boost, so I can run a tune with over 300rwkw on the street, lag is only marginally higher, and I believe it will get lower with the right tune, but still enable control with the right foot.
I am using a 40mm wastegate, and it was fine with the 0.61 housing, as it is with the 0.87.
If you are going to the 3L bottom end, I beleive the 0.87 would be too small, closer to 1.0 would be my choice.
Ive bought a 1.12 housing because it would suit the 3.0L later down the track because its a project, but as its going on the rb25 very shortly and i dont want monster lag. Therefore i thought a smaller wastegate would help reduce this lag.
As for the TO4E, It was rebuilt with a 66mm compressor wheel. It needs to be balanced before put on as the previous company did a shit job. I do have the original housing of 0.69 but i think it would be 2 powerful. :wassup:
The 3L wont be ready until a couple of months because its a slow project build and money counts. The 3L is real as ive got the short block all prepared for the head and everything else. Waiting to purchase pistons so thats gona cost a bit, well thats another story.
Oh yeh tunning plays a big part of performance and response but also purchasing the correct size wastegate and manifold helps also :) Well im gona have a HKS To4 tunned manifold and not sure on the wastegate.
Hey what's the specs for your compressor housing?
so its got a 66mm T04 compressor wheel (what trim?)
what's the A/R of the compressor housing?
is there some sort of rule to choosing a compressor housing when you've decided on the specs for turbine housing?
I think the turbo has a T6 front with a T4 end.
I dont know details on the turbo as it was a dudd turbo that needs fixing so all i know is that its a 60 or 66mm compressor wheel. :)
If it's the T66 wheel (66mm) then it's pretty damn good - the comp map for that blade is awesome. Should be good for at least 700hp. But to flow that much you're going to need the rest of the support systems, and spec the turbine end not to be too restrictive.
hmm sorry to drag off topic, but my mate has a VL turbo, which has most of the good bits in it and namely a GCG hi flow turbo (T3/4 hybrid i am guessing), not long after he bought the car the turbo carked it due to a crimped oil feed line. so he ordered a new turbo from GCG, specs not exactly known.
put it on ran it at the drags and then had another problem with the car... unrelated. after fixing that problem, he decided that the exhaust a/r was too small and sent it back to GCG. after they had it a month it was sent back and told doesn't need too be done.
2 weeks ago car was dyno tuned and the best possible run was 204rwkw. now he (and i) were expecting a bit more than this. as it is not laggy at all, and boosts quite quickly
why would GCG refuse to do this?
it is getting sent back there one more time to get DONE and if they refuse, TUFF!!!
nag, wastegate dont affect lag. it only opens as per the boost your running.
how well it holds boost depends on the size and how much it opens etc.
204rwkw is bugger all on a vl when you consider the stocker turbo will make 180rwkw.
a stocker T3 hi-flow (different wheel on comp/exhaust) makes 230rwkw on average. thats with the stock housings just machined a bit
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
