A Friend of mine had these bits for a couple of Skylines he imported himself etc.
Garage clear out.....
Part QTY Price ($)
32r turbo good 1 600
32r turbo bad 1 200
32R dump pipes pairs stock 3 200
32r manifolds pair 2 300
air con fan 1 100
r34 gtr turbos ball bearing ceramic exh wheel pair 1 2200
apexi air filters new gtr r32 1 340
greddy pillar twin r32 gtr 2 150
greddy remote oil filter set up r32 gtr 1 300
clear blinker front 1 450
tomei cam sprockets rb26dett 1 550
greddy clear cam sprocket covers 1 180
power ent timing belt rb26dett 1 220
r33 cusco/nismo front strut bars 6 150
r33 carbon fiber radiator panel 1 400
r33 rear wings 3 100
mood oil cans 1 150
greddy oil cans 4 180
cusco oil cans 1 180
field a/f monitor 3 100
greddy profec b spec 2 1 550
sard fuel pump 3 550
sard fuel pressure reg small 2 280
pivot shift light 2 200
apexi avcr 1 800
z32 mafs inc harness 2 350
TD06 20G Turbo rebuilt with new core, HKS 60mm wastegate, Trust manifold, dump pipe. All ceramic coated. Looks very nice.
All fits straight onto an SR20
Contact me for more info if needed.
michael
also have
mood oil cans 1 150
apexi avcr 1 800
pics of the greedy filter kit, i have someone who needs one.
getting pics tonight.
its brand new in a box though...
not too much to see! :headspin:
Currently got some pics of the Rear Wings (2x aftermarket wings for 33 and 1X R32GTR wing)
Pics of the strut braces
Pic of the Greddy remote filter kit.
Mood Motorsports catch can.
And a TD06 Tubo Kit for Sr20.
hi mate,
yeah can send pics, but dont have an R33 GTR wing sorry.
One is an R32 GTR Wing,
Other two R33 Wings are quite large ones will send you pics anyway if you like.
michael
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
