  • 3 weeks later...
New boost controller installed and it got its tuna. Running high and low boost settings.
235kw @ 8psi
290kw @ 16psi
Kept breaking traction at higher boost so will be adjusting the wheel alignment and bringing it back in for another run soon.
  • Like 1
Before wheel aligning I had to make some more room under the guards so prepped up the fibreglass guards which gave the front wheels plenty of room to move.
post-89239-0-20096900-1463271408_thumb.jpgpost-89239-0-04859400-1463271501_thumb.jpgpost-89239-0-56296100-1463271546_thumb.jpg
Painted them and then decided I hated them on the car. They ruined the lines and look rubbish.
So I went to town on the standard guards instead. I cut the inner lip off completely and then flared them out as much as possible. They're a bit rough but they work. Might smooth them off properly and paint them, or might just buy gtr guards we'll see.
  • Like 1
Flared/Pumped out the rear guards as well with the heat gun, baseball bat and phone book method. With a lot of patience it actually worked out really well, they're a lot more roomy. Then spent a couple of days with Heasmans getting straight.
Checked the plugs yesterday then spent a little more time on the dyno. It running nice and clean, still needs some work at higher boost but it's happy as a pig in mud at around 12psi. Drove it straight off the dyno and out to Eastern Creek for some drifts around the skid pan. Drove it hard all night and it behaved itself like a gentleman, then drove it home again afterward.
So good to get some wheel time without something breaking on this thing. It's been solid af lately. Should see some track time very soon
Thanks mate!!
I'm from Epping. Where are you from?
You'd have done well to have seen the car around Sydney it's spent almost 6 out of the 7 years I've owned it locked up in my garage. Last week was its first ever trip to the creek
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
