  • 3 weeks later...
New boost controller installed and it got its tuna. Running high and low boost settings.
235kw @ 8psi
290kw @ 16psi
Kept breaking traction at higher boost so will be adjusting the wheel alignment and bringing it back in for another run soon.
  • Like 1
Before wheel aligning I had to make some more room under the guards so prepped up the fibreglass guards which gave the front wheels plenty of room to move.
post-89239-0-20096900-1463271408_thumb.jpgpost-89239-0-04859400-1463271501_thumb.jpgpost-89239-0-56296100-1463271546_thumb.jpg
Painted them and then decided I hated them on the car. They ruined the lines and look rubbish.
So I went to town on the standard guards instead. I cut the inner lip off completely and then flared them out as much as possible. They're a bit rough but they work. Might smooth them off properly and paint them, or might just buy gtr guards we'll see.
  • Like 1
Flared/Pumped out the rear guards as well with the heat gun, baseball bat and phone book method. With a lot of patience it actually worked out really well, they're a lot more roomy. Then spent a couple of days with Heasmans getting straight.
Checked the plugs yesterday then spent a little more time on the dyno. It running nice and clean, still needs some work at higher boost but it's happy as a pig in mud at around 12psi. Drove it straight off the dyno and out to Eastern Creek for some drifts around the skid pan. Drove it hard all night and it behaved itself like a gentleman, then drove it home again afterward.
So good to get some wheel time without something breaking on this thing. It's been solid af lately. Should see some track time very soon
Thanks mate!!
I'm from Epping. Where are you from?
You'd have done well to have seen the car around Sydney it's spent almost 6 out of the 7 years I've owned it locked up in my garage. Last week was its first ever trip to the creek
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
