my car has had a pull to the left for a while now, it has had a few alignments over this time and it hasn't ever seem to fix it
it has had new tyres put on in january this year, there are new (less than a year old) rubber bushed adjustable castor arms and bearing jointed camber arms up top and the tie rod ends were replaced with ball jointed items about 18 months ago the day before i bought the car as part of the road worthy
i can't quite confirm but sometimes i think there is a very fine vibration coming from that side, which had me thinking today possibly wheel bearing
anyway i jacked each side up before and there isn't any movement when i grab the wheel on top and try and move it but when i grab it either side and move it there is a small bit of movement, the right side wasn't as bad
so i'm thinking it's either to do with the ball joints or maybe the steering rack has some movement?
wheel alignment specs
camber: -2.5º both sides
toe: +0.5mm each side
castor: about 6º i think
any input would be great thx
https://www.sau.com.au/forums/topic/412097-r34-gtt-pulling-to-left/
When you say side to side I assume your grabbing the tyre on the left and right and moving it? Not top and bottom?
If that's the case the rack end is probably worn and the alignment specs may look good on the machine but are out due to movement while driving
Either way a competent wheel aligner should have checked these things for you?
Checked brake pistons? Pads wearing evenly? Have you got adjustable castor arms? Road camber will tend to make you drift to the left a lttle - you can run 1/4 to 1/2 deg more camber on the left to compensate.
(BTW check the rear brakes for dragging as well)
primative, but works..
Measure the distance from LHS front axle to rear, then RHS front axle to rear. LHS and RHS should be the same, there's even a chance the stock subframe bushes are farkkkked and the subframe is sitting a tad off.
yeah johnilicte the last wheel alignment i had done there is a measurement on the sheet that measures exactly that and there isn't a major difference
the movement is left to right so it's probably the rack end, sort of surprising as they aren't that old but at the same time not that surprised as the old front tyres on it managed to destroy a ball joint on a castor arm in about a month due to the vibration i was getting (old worn federal rsr's)
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
