  • Replies 88
Yeah, members got priority and it filled up pretty damn quick.
Come down and see some mental cars though.
Also, come hangout here.
http://www.skylinesaustralia.com/forums/topic/402647-whoretown-ics/
If you feel so inclined.
little sleeper, "apparently" my lazy arse friend that runs Hensperformance is going to organise a private wakey day.. he still hasn't but when he does would be good if you came.. mainly FWD day
That would be awesome!
Let me know when/if that happens. I'll be in for sure! :)
I've got a few other bits and pieces I wanna do, mainly bolt ons, like 4-1 headers and gotta do something with the intake manifold, it's choking it a bit oh and 3" exhaust.
please do rape them.. all honda owners think their cars are the best
And they deserve to, I regularly see civics and integras put skylines and falcodoors to shame at willowbank....
Have you seen inside their cars? they strip it to a point there's just bare metal hence they go quick. Imagine they weighed as much as a liner, 20 sec 1/4s for sure
I like my car full trim thanks.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
