In the process of changing over my turbo's, got the rear one all hooked up and ready to go.
Starting putting together the front turbo, but the oil hose/line doesn't sit nicely and you can't get the hose on that goes to the block.
Anybody else had trouble with this?
See Pic to help with my crap ass description.
Hooks up to the bottom of the turbo, then a rubber hose goes to the engine (sump to drain back the oil)
Edited by Booki
I think drilling out the wholes would effect the seal, Had a attempt and bending it with a blow torch, wouldn't budge. ended up warping it a bit...
So you got those eBay links handy..?
It's a tough little piece of pipe.
If i did that, not sure if i would damage the seal from the base to the pipe, or if it would snap :\
Might just buy one from GCG/eBay, pending if i can get one local or not.
Tunes booked in on the 5th of November, so gotta get this puppy back together asap.
You should piss it in. It's only a 8-10 hour job total
What did you end up doing?
Modified the stock drain which was a big headache as it kept pissing oil, after the 3rd fitting it finally stopped leaking oil, really should have brought the aftermarket drain from GCG though
Just ended up replacing the bolt on the turbo with one with a smaller head so it gave me clearance for the pipe.
Just walked into Rotomaster and somerton, the fella their smoothed out the base of the pipe and provided me some gaskets and the bolt for free! Champion!!
But now ive almost got it all back together, But wondering what the hell is this ground for?
Clip then it goes to a ring connector, sorry for the shitty pic. Any idea's? Looks like a ground for something :\
Also, do people bother putting on the turbo support/braces back on? It looked like such a C*&T to fit so i didn't bother wacking it back on. The turbo's are rock solid and held firmly in place from the Dump/frontpipe and the exhaust manifolds. I doubt the turbo support brace really did anything.
Edited by Booki
Sweet ground strap should be no problem to hook back on with everything back on, (im hoping). does anyone actually know what its for/does?
Hmmm, would you say its important to strip everything out of the way for those braces? Ill have another sticky tomorrow to see if i can get it on. What would you do in my situation scotty?
Also - Draining the engine oil and gonna put some coolant in and start it up for the first time !!
Anybody recommend a particular type of coolant? Or just throw in what ever?
Edited by Booki
I assume the ground strap is to stop corrosion, I usually remove them as they get in the way.
The braces I would be fitting back in place, I know they are a pain but they are there for a good reason, especially if you plan to dyno/track it. The one time I fitted 32GTR turbos for someone, the shitty old stockers I was asked to install back in had stripped threads which made the braces useless.
Don't mix coolants, especially if you have an alloy radiator. Give it a good flush with plain water first then drop it again.
Stock Radiator, So just grab some premix coolants? Is that what you meant? I honestly have no idea what coolant was used prior, this will be my first coolant change in my GTR.
Will have to have a good look underneath and see if i can get the brace back on.
    • Good timing mate, welcome to God's country just in time for winter Seriously though....how cheap is rural/regional.
    • Thanks guys! Some pics attached 馃構
    • Big enough for you, Jackie, and some puppers mate! I vote some GSDs, but I am biased   How big of a block is it on?
    • Well, fun day was had, I finally found a house that will do me just fine, 1980's brick build, but with full fresh renovations, plus new colour bond fencing all round so puppies are incoming 馃悤, and water tanks for the garden, and it's located in West Goulburn..... @Duncan 馃, so day trips to Wakie to watch cars going Zoom will be on the cards In the end it cost well under my budget and was actually better than alot of the more expensive joints I was looking at, it is in a good area, close enough to the shops, public transport, and the Wollondilly River Weir,  and the great walking paths along the river, but far enough away from town to see minimal traffic The deposit is dropped, the conveyancer is conveyancing and I should get the keys in a week or 2 as the property is currently unoccupied  As with everything I own, I'm doing up a modifications list, as it doesn't have solar, that is first up on the big list, all of the panels and enough batteries to keep the joint warm, or cool, followed by a largish carport out the front, the small list, which will start as soon as I have keys, is some security stuff, like cameras, screens, and the usual "crazy prepper" additions that weird old people like (mouse holes to stick shot guns out of, and the usual man traps that the average person installs for the unsuspecting and unwanted guests 馃ぃ) The gardens front and back are OK, but, not to my standards or liking, so landscaping will be a fun job to start getting into, so when spring is sprung I'll do a heap of planting, lots of natives and vegetables is the plan, the old owners were more "Old English Garden" type, so basically Roses and other weird looking things that are destined for the green waste bin One thing that is staying garden wise is a nice established hedge out the front, it is about 5 foot tall and covers the whole front of the property from prying eyes As for the car hoist, the roof in the garage has some height to it, but, I'll need to get an installer out to see what can be done, width wise may be a issue, but my building inspector will be getting back to me over the next week with his recommendations  Small, but cosy
