Hey everyone, new to forum and just bought my Stagea. Beaut car. Was just wondering can anyone suggest a really good value for money 3 inch turbo back exhaust with high flow cat? Hit me with anything no matter how loud or quiet but really keen on at least a nice toned 3 inch sized zorst.
Cheers heaps,
Mitch.
https://www.sau.com.au/forums/topic/412148-wgnc34-exhaust/
Hey mate, welcome onboard. Firstly the biggest thing round here is the search feature. Using it will help u lots and avoid flamings. Try the sau business traders (such as just jap) as they have exhausts for stageas. Theres lots of options so search, search, search. :)
https://www.sau.com.au/forums/topic/412148-wgnc34-exhaust/#findComment-6592330
unless the std exhaust is holding you back from making power leave it!
first try a front pipe, high flow cat, and a bit more boost (11psi) - best to get it done on a dyno to see how the motor responds
i have the above mods and my car makes 120rwkw, and for a street car its more then enough go to keep you busy and all in silence!
focus on getting it to handle right before going for power, which will mean front mount, exhaust, ecu and tune (decent $$)
if its a daily driver believe me there is nothing worse than the drone of an exhuast echo'ing through a wagon..!
i fitted a 3" turbo back with 2 mufflers, and sure it sounds great when your revving it in your driveway, but at 6am on the freeway on the way to work it will do your HEAD IN!
my 2 cents :cool:
https://www.sau.com.au/forums/topic/412148-wgnc34-exhaust/#findComment-6593785
my 2 cents :cool:
Thats where u went wrong. Mufflers are to reduce noise, resenators reduce drone (also known as resenence). 1 look at 90% of the jap exhausts will show them with 1 good muffler and a cannon (which is a resenator). Cut off the 2nd muffler and get a cannon or any other resenator and it will be 100 times nicer. After a really bad droning exhaust being made by a shop. Ive done 4 different exhausts on my stageas trying to find what works best to reduce drone, the resenator and muffler combo works best.
https://www.sau.com.au/forums/topic/412148-wgnc34-exhaust/#findComment-6594584
Im running GKTech Stainless 3inch Dump, front & decat pipes. That cat back is a stainless Trust system that was on the car when I bought it. It does drone abit (more noticeable with the windows up) but you have to expect a bit of drone. Sounds great when you get up it!
The GKTech items are all to suit R32/33 and are VERY well priced. Fitment was great.
https://www.sau.com.au/forums/topic/412148-wgnc34-exhaust/#findComment-6595152
Anyone got a titanium system? I've spent so much money on my exhaust I could have bought one. But do they sound nasty? I'm either going to get a complete custom made one or get something like an HKS silent power (I want a 3 1/2 in system but they are quite hard to come by which is why I am considering a custom made job).
https://www.sau.com.au/forums/topic/412148-wgnc34-exhaust/#findComment-6597667
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
