Try calling a company called cruise control specialist in sydney see if he has a contact in melbourne. or a company called autron in melbourne they sell cruise controls they might have a reccomended installer.
The ones I supplied were AP-900C as sold here by C0mmand. The 'C' is for CAN-bus, but that part didn't work in our favour, so the (cheaper?) AP-900 will do.
If you get someone to supply/install one for you, get them to leave the stalk unmounted. Nicest result is with the backlit steering wheel controls. Can buy them from Nissan for $75 - $80, & that includes the stereo controls as well - ie both sides of the wheel have buttons.
The AP900 is user programmable for response/overrun etc. Very handy if you make changes to your car (especially different turbo) as it allows you to change the settings to suit yourself.
Chris' kit should come with steering wheel controls, but they are the older style (from what I have heard/seen in the past) & don't come with LED backlighting. Not a big deal I suppose, but those of us with the newer switches really appreciate not having to remember what button does what in the dark.
I heard from a M35 owner in the Newcastle area who found someone to supply & install one like mine for ~$750 (no switches), & I thought that was a pretyy good deal for a locally sourced unit.
If you don't want to think for yourself & do much chasing around, then get one from Chris as it will work fine.
Before I bought 20 in from the manufacturer, Chris didn't allow DIY install on his, & the installed cost was $900. I wouldn't have bothered if I could have bought his kit for ~$700 & installed it myself. Looks like he changed his mind.
In case you are wondering, most people bought mine for <$500 inc switches
I recently had the Command AP900 system fitted to my car for $750, Freeway Car Audio in Dandenong.
They will probably want to check the car out first to make sure/double check wire colours for the harness.
The kit I got has the RF controller, no stalk at all and the passengers in the back can set the cruise.
Noted :ninja:
That's a good price, for Aust supplied retail.
Not sure about the controller tho. Besides not wanting anyone else playing with the CC whilst I'm driving, it will need batteries every now & then. I had a few C0mmand IR controllers on my work car stop working (break) before I tossed the lot out. Your RF one may be more reliable, but I like that the factory switches are good quality, wired in & just for the driver, lol.
It took about 3-4 hours from memory.
That's pretty standard for 1st time. (It took me >2 months to get mine going initially, haha).
Like anything, subsequent times would be much less, ie <2hrs.
The factory switches are the reason why I went for the RF remote, once installed I will be able to throw the RF controller in the glove box and forget.
Ahh, I see. Good choice :)
If you need any info/help on setting up the switches, read my thread on m35stagea.info or message me.
Wow thanks for the in depth info guys. So far I have rung Autron and their Melbourne installer No Limit want $880 to supply and fit an Autron cruise complete with the little control button box to go on the side of the wheel or a stalk.
Chris charges $710 delivered for his cruise which includes the Nissan switches (can't confirm if backlit or not), he said it was a Lawrence & Pederson unit that is commercially fitted to a number of vehicle brands.
The deal from Freeway Car Audio seems pretty good then, I guess the only thing I'm thinking now is, if I DIY my cruise, sell the car and it malfunctions, who's arse is going to get kicked for it? Is there legislation covering the installation of cruise controls?
So I rang Freeway, they quoted $690 installed for the CP900 which seems very reasonable.
I'd probably just get them to fit the stalk as I'm used to a stalk and think it is the most ergonomic arrangement for my hand when my arm is resting on the armrest whilst cruising. You can just adjust it with your fingertips instead of having to move your hand onto the wheel centre itself. Just my 2c of human factors engineering.
PV were you satisfied with the workmanship and the quality of kit itself?
CP900 or AP900?
In any case - good price for installed cruise, especially if you want to use the stalk. I think there's really only one spot to successfully mount the stalk & Andrew's turned out good in that regard.
Not sure about ergonomics, but if it's good enough for the factory...
Plus you get audio controls thrown in. That's worth the effort IMO.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
