Quality of the kit is excellent, and was installed nicely.
The 'ON' LED is mounted next to where my VDC button is so that you can notice it but its not glaring in your eyes.
And the guys there are real easy to deal with, nothing is a hassle.
Edited by pv35gt8
Did you ever get your audio controls setup and working Leon?
It's on the to-do list. Will connect them next time the centre console comes out.
Nice one. On my to do list is to fix the cruise control. Wires to the buttons seem to have popped out and now I can't seem to get it to turn on... Weird...
Audio controls would be nice but I have an aftermarket head unit anyway so not sure if it would take the inputs.
In any event I could always retrofit the switches at a later time, thanks for your input guys will post up with how it goes.
A lot of A/Mkt head units have the ability to work with steering wheel controls. You connect the wires & follow a learning procedure (just a different resistance value for each operation). Worthwhile checking if yours will work, but you're right, you can retrofit in the future. Let us know how it turns out.
Do you have any units left Leon?
Somewhere I have 1 unit which is/was being held as the warranty spare. Someone wanted it but I forget who now, & they haven't paid nor contacted me. I must find it one day & sell it to someone....
  • 1 month later...
So Freeway Car Audio decided they couldn't do a drive by wire Stagea (meaning an M35) and I ended up buying Chris Rogers cruise control.
Installed it today with some guidance from Scotty and a phone call to Chris, instructions were good and it was actually remarkably plug and play but don't take that to mean it was a walk in the park.
I wouldn't advise doing it solo without some research first and/or someone who can navigate underneath the dash of a Stag. Having done it once I'm sure either Scotty or myself could do it in an hour so drop us a PM if you need some guidance.
The unit itself is a neat fit into the car, functionally it's not quite as refined as one might expect from the factory but is nevertheless a good unit that gives basic cruise functionality (set, resume, accel, decel, cancel). I would recommend it to any others who may search up this post in the future. Thanks again to Scotty and Chris.
Should have followed the instructions Leon posted on m35stagea.info. Not too hard at all, just a bit of a pain.
Ironic I know, it was the DIY install that scared me away initially hence setting up the thread.
Now I can drive to Sydney nice and easy, can't wait to see just how good the fuel economy will be when you don't have to stop/start. I'm hoping for 10L/100km, really depends on whether it's boosting or not at 110km/h.
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
