Quality of the kit is excellent, and was installed nicely.
The 'ON' LED is mounted next to where my VDC button is so that you can notice it but its not glaring in your eyes.
And the guys there are real easy to deal with, nothing is a hassle.
Edited by pv35gt8
Did you ever get your audio controls setup and working Leon?
It's on the to-do list. Will connect them next time the centre console comes out.
Nice one. On my to do list is to fix the cruise control. Wires to the buttons seem to have popped out and now I can't seem to get it to turn on... Weird...
Audio controls would be nice but I have an aftermarket head unit anyway so not sure if it would take the inputs.
In any event I could always retrofit the switches at a later time, thanks for your input guys will post up with how it goes.
A lot of A/Mkt head units have the ability to work with steering wheel controls. You connect the wires & follow a learning procedure (just a different resistance value for each operation). Worthwhile checking if yours will work, but you're right, you can retrofit in the future. Let us know how it turns out.
Do you have any units left Leon?
Somewhere I have 1 unit which is/was being held as the warranty spare. Someone wanted it but I forget who now, & they haven't paid nor contacted me. I must find it one day & sell it to someone....
  • 1 month later...
So Freeway Car Audio decided they couldn't do a drive by wire Stagea (meaning an M35) and I ended up buying Chris Rogers cruise control.
Installed it today with some guidance from Scotty and a phone call to Chris, instructions were good and it was actually remarkably plug and play but don't take that to mean it was a walk in the park.
I wouldn't advise doing it solo without some research first and/or someone who can navigate underneath the dash of a Stag. Having done it once I'm sure either Scotty or myself could do it in an hour so drop us a PM if you need some guidance.
The unit itself is a neat fit into the car, functionally it's not quite as refined as one might expect from the factory but is nevertheless a good unit that gives basic cruise functionality (set, resume, accel, decel, cancel). I would recommend it to any others who may search up this post in the future. Thanks again to Scotty and Chris.
Should have followed the instructions Leon posted on m35stagea.info. Not too hard at all, just a bit of a pain.
Ironic I know, it was the DIY install that scared me away initially hence setting up the thread.
Now I can drive to Sydney nice and easy, can't wait to see just how good the fuel economy will be when you don't have to stop/start. I'm hoping for 10L/100km, really depends on whether it's boosting or not at 110km/h.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
