hi all im new to sau hopefully this is in the right section,
ill get straight to the point,
i bought a r33 which has been fully rebuilt 2000ks ago forged internals, plenum, high mount manifold, hybrid or garrett turbo cant remember what it is, apexi fc, hybrid fmic, coilovers, fuel reg, 044 pump, been told by the owner it had a GTR oil pump fitted when rebuilt, now i bought the car without hearing it as the owner pulled the head off, yes i know stupid thing to do but i got this r33 cheap... cheaper then buying a 6boost plenum and high mount manifold...
now the old owner said reason why he pulled the head off is because he started to low oil pressure (cluster gauge) took it to the engine builder not sure if he checked it over but anyways told the owner the cluster gauges always stuff out common problem anyways, the old owner said that the car lost all power like it wasnt making boost...
now nothing has been said about a drive collar been put on the crank for the GTR oil pump do you believe the pump has shit its self and thats why it had no oil pressure and now stuffed the motor?
i have spoken to the engine builder and he hasnt said boo about a drive collar fitted...
old owner story always changed he was also on rev limiter when it f**ked out... my guess is oil pump shit it self
i will be pulling the motor apart to inspect just thought ill throw this up
https://www.sau.com.au/forums/topic/412184-forged-rb25-dramas/
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
