  • Replies 80
There's a handful of different reasons ranging from heavy clutch kicking, revving too high, poor assembly of the engine when it was rebuilt, damaged crank prior to rebuilding but wasn't picked up before it was assembled......and the list goes on
I'd need to see every single piece in detail to be able to tell you exactly how it failed.
I know the old owner and heard story's that he loved to reclutch it everywhere.. Also the high revving he use to do as well, I believe the crank that was in it was in good form and it good balanced and all
No, but it will have been damaged by the same f**k-knuckle driving as damaged the motor.
speaking of engine damage, does a few bounces off the limiter cause any of the above issues, i set my limit to 6000rpm but when the tyres loose grip its bit hard to stop it bouncing off it, id imagine in the drift and drag area they'd be doing this all the time..
My limiter is set 300 higher than I plan to take it just so I never hit it
Yeah, that is the heart and soul of the problem and one of the solutions. Limiter bashing is very bad. Occasional limiter clipping is probably OK, but Murphy's law dictates that you will break an oil pump drive even on an occasional limiter bump. If the engine won't self destruct by running at faster revs than some notional rev limit, then it is better to let it just rev up over that notional rev limit occasionally, rather than hit an electronic rev limit possibly more frequently.
Edited by GTSBoy
Yeah, that is the heart and soul of the problem and one of the solutions. Limiter bashing is very bad. Occasional limiter clipping is probably OK, but Murphy's law dictates that you will break an oil pump drive even on an occasional limiter bump. If the engine won't self destruct by running at faster revs than some notional rev limit, then it is better to let it just rev up ober that notional rev limit occasionally, rather than hit an electronic rev limit possibly more frequently.
thanks for the info, will raise it back up and be careful then
cheers
cheers
Can also retard timing tapering back from your desired limit a few hundred revs.. Ill be getting this done on my next tune. that way you lose lots of power before limiter so you wont be going near it deliberately. And it softens the limit somewhat I believe. i.e. my limit is 7700 atm, start retarding at that to a 8000 limiter..
Has anyone got feedback on this idea?
And back on topic, how much kicking has one got to do to abliterate a thrust bearing!?!?
Haha yep f**ked on a hole
New level,
Not using anything off that motor apart from the head and cams
Started all over, bought a block girdle and crack, rods bearings main studs, motor should be finished been built this weekend
That is shockingly bad. Whatever the problem the owner would have known this engine was seriously broken LONG before he took his foot off the loud pedal.
Go out and buy a stock RB25, go from there. You can keep some ancillaries from this engine as spare.
Personally I'd take it to a different engine builder.
Hahaha funny thing is, when the owner was trying to sell it he was saying the day after it bogged down and it got hot he started it up and there was no knocks or anything... BULLSHIT lol thing would of been knocking its head off,
I got the car pretty cheap knowing something big or small could be stuffed didn't think this much damage would of been done in 2000ks tho
Yes I have started again with a NEW bottom end and the motor is been built by a different person (not the person that built it the first time)
Wow man, I just had a read thru this thread....
What a heartache, half of me feels sorry for you...
The other half says 'serves you right' for NOT test driving a car before purchase! Mate, that is such amatuare mistake to make. Sounds like you got caught up in the moment, the word 'skyline' tends to blind ppl to the obvious sometimes. Hopefully this whole experience opened your eyes a bit and has made you more cautious about buying things without inspection in the future.
What I am interested in tho is,
What was the total cost to get it runing again at the end of the day? (includes original purchase price, parts and labor)
Cause from what I have seen, it sounds like it could of cost a fortune.
Lol first of all mate, I bought the car off a mate, already knowing something was wrong with it, etc (head was already removed from car) no one new what could be wrong with it and on purchase I knew it could turn out to be a f**ked bottom end, and it doesn't bother me as I paid for the car at a low price (what some people would pay for rego and insurance)
I only had to build the bottom end, but I've also gone with nitto rods nitto oil pump ho volume sump new garret gt3540 new plenum new throttle body
Just seems like a hell of a lot of trouble to go thru to get a working/running Skyline.
There are 33 out there (running) for like $5K. I was just interested as to why you've chose the 'hard road' so to speak?
Might just be me, but anyone that sells you a lemon is no 'mate'... Unless he didn't want to sell it to you because of the issues with it, but you insisted, in that case he is quilt free.
Everybody's logic is different, but I just don't see the sense in buying a wreck? I could maybe also understand if you had always wanted a skyline but didn't have enough cash and then this popped up at the right price, so u grabbed it.
I'd still love to know the total cost of this exercise $$$? But if you don't want to say, I will respect that.
Either way, best of luck with it. Hope it works out.
Edited by AshR34GTT
Could have a running car for $5k but it wouldn't be anywhere near what his car is going to be and sounds as though he paid that little that if he wanted he could get a stock rb25 motor drop it in and still have done well
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
