As topic say i have an Trust 10 row oil cooler for sale. It is an genuine Trust item . I am after $350 for the cooler itself or $700 for the adapter and hose.
Let me know if you require more information on [email protected] or 0418 388 125
Thanks
Calvin
https://www.sau.com.au/forums/topic/41222-trust-oil-coole-for-sale-350/
With the adapter and hose what make skyline will it fit or are the adapter plates similar??
Pictures would be nice :Pozemail.com.au]rchrzanowski@[spam]ozemail.com.au (remove [spam])
Interested in the whole kit. thanks Rob
I only have the cooler with me at the moment but i have check out the price for skyline adapter which only cost $75 max. hole is about $75 a meters ... hose join is about $25 each * 4 = 100 and if you after a remote oil adapter is about $75 for adapter as well and another 4 hose join and hose.
Hope i make this clear that how it makes the whole kits $700.
From engine oil filter adapter = $75 max new
Hose to oil cooler = $75 max new
Hose join (need 4 of them) =$100 max new
+(if you after remote oil filter)
Adapter from oil cooler to filter then to engine=$75 max new
Hose from oil cooler to adapter to engine = $75 max new
Hose join need 4 of them =$100 max new
Oil cooler = $350
Let me know which application you after
Sorry guys i lost my internet connection for last 2 day and hardly get a chance online.
Anyway below is the answer that been ask
GTR032 = Pic send
Scotsman = link above to the pic and as for what car? To be honest i am not sure but from what i found out it is design for R32 and S14
RedLineGTR= I dont have adapter and a new one is cost $75 for most car and i only have the cooler and i am after $350 for this cooler
Size
12 inch long
5.5 inch hight
2 inch thick
Thanks
Calvin
As you can see from the picture above An R33 GTR is using this same cooler... what i mean is same size... the different between the size is depent on what application you are after. This is an entry level but then if u have 700Hp car and race on track,,, then u should be getting a bigger one or else this should be fine
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
