Unique & Interesting Places In Melbourne
  • Replies 79
Squire's Loft has a decend steak
... i cannot believe someone suggested knox - ozone...... i always thought it was called Hozone
I've been meaning to go there, I need a good steak.
Cheers James will look these up when i have a chance
Der Raum is my absolute favourite place to chill/hang out with friends, this place is definitely special/unique and it is awesome. Generally only have one or two drinks (it's about $25 for one) but its definitely worth the experience.
Maha has good food, not cheap, but not overly pricey either, although admittedly I was quite disappointed the last time i went, they do however have a very nice Shisha lounge and fantastic atmosphere
I can recommend a couple more places but they are a tad on the "only go if someone else is paying" side
All this Ftg/ringwood talk and haven't seen any of you around!
I live next to mountain gate and work next to manhatten haha
Shout out to my ferntree gully brothers!
Sounds like a bogan Ftg/ringwood night is in order.
I work in baysie and live ringwood area, moving to ftg soon. See a couple of peeps on my way to gym and about, nothing on spotted lol
But on topic, plus another 1 for crownTry something for dinner, Theres quite a mix. Had something once was nice good service, can be pricey though.
And go get yourself lost on the casino floor :P
Ex GF lived in FTG right next to Mountain Gate...never again, never again.
Some of the best Coffee places in Melb:
St Ali (south Melb)
proud Mary (collingwood)
Seven seeds (Carlton)
If you have an iPhone, download the Beanhunter and Melbourne coffee review apps. They are usually a good source of venue hunting.
Sorry mate...
you definitely need to try these places for Coffee...
DI BELLA - Leveson Street North Melbourne... Absolute best coffee!!
Oli & Ari - Were Street Brighton - Awesome food and marvelous coffee!
Auction rooms - North Melbourne.
Easily the best at the moment!! :yes: Check them out you will agree!!
    • For the record, I hate the colour. Even if I'll never see it again, I know its in there.
    • This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails.  As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
    • Welp don't know if this is good but I can hear a sizzling sound in my battery Hope I didn't fry it. Turns out a bad battery in the multi meter will give a false reading (likely what happened when I said I had 15x volts), swapped the battery and monitoring now. I'm hoping that sizzling sound is just the equlisation charging
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
