They do know the main 120L tanks capacity, but they don't know the level in the 10L swirl pot that's inside the tank bladder.
The car should start with 120L and a full swirl pot.
So in theory using 1.2L/km they should be able to go 108km's at race speed which the other 3 nissans did.....
Problem rick would have had was that he had several cars wanting his position so he'd have been using more fuel during the race to maintain position.
Who knows why but the older engines are still running group fired injection and single coil dizzy setups. The nissans and Mercs are fully sequential multi coil arrangements but they can't get onto the consumption of the dinosaur push rod engines, they are just that efficient.
Brad, I was under the impression (from the Motec V8 support personal) that the COTF engines are all sequential and individual coils (powered by the new M1xx series ECU's) The teams had the option of running either group or sequential firing on the old engines (with the M880 ECU), with most using group fire as it left a few outputs available to be used elsewhere on the car, prior to the development of PDM's E8xx and SVIM's.
They are correct.
The COTF engines are run sequentially. The holden version is based on the LSX engine frame from GM performance.
The older aroura engines most of them are using are still being run in the exact same way as they were last year. Grouped with single channel CDI and coil.
I'm not aware of anyone using the V8 supercars supplied and homologated engines that are seq run. Perhaps when other manufactures come that don't produce a V8 we will see those engines being used.
The pace built and V8 supercars owned chassis do have the homologated "off the shelf" engines fitted.
Thought the COTF tanks were 112 litres or similar?
  • 4 weeks later...
Nobody mentioning that Gary Rogers will be running two Volvos next year?
Good to see the series kicking a few goals re manfacturers. Next test will be to get some satellite series going and then have a 4 World Championship rounds. Spa, Bathurst, a US circuit and Silverstone or something
  • Like 1
Yeah good on em for taking the punt!
It will upset a lot of people but i like the fact that its not just the old Bogandore and Foulcans!
I don't think it will upset many at all.
There are a LOT of diehard fans... They may not be upset now but when the other makes catch up and start winning races they might ;)
I don't see any of the new manufactures winning races anytime soon. I think the mercs will probably be the first to do it, followed by the volvos and then the Nissans (if they ever actually win, which I doubt with the current driver lineup)
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
