Hey ive got a rb25neodet from a 34 in my skyline, basicly pulling it down wire tucking to remove headlight loom and other wires.. While doing so, I had spotted that my motor was running without knock plugs? are they neccessary? its got a impul chip computer i believe , And i think It ran without knock plugs over the span of matsuri 24hr drift? nothing seemed wrong and the motor ran awsome!
Can i delete them from my loom? or should they be there.?
https://www.sau.com.au/forums/topic/412265-knock-plug-help-rb25neo-turbo-motor/
The ECU should chuck a fault code if they are disconnected. If the knock sensors are not reading any knock (ie, connected to loom but not attached to block) then the ECU will continue to run the ignition advance at whatever the maps say to, without swapping to the knock map. As long as the map values are not causing knock, then all is good. If there is some knock though, the ECU can't know about it and can't do anything about it.
If your car has the knock sensors screwed into the block, but the plugs unplugged......you might want to plug a Consult unit in and see if it is throwing codes or not.
Ive just looked are the plugs , knock plugs go to 1 plug that have wires which also return to the fuse box (very small wires) 2 of which are cut, but. the wires from the knock sensors are still attached, ive plugged in back to the engine loom? will this still sense knock etc or were the 2 smaller wires acting as a current feed?
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
