Just did the ECU reset, made a huge difference
1st gear now holds all the way to 6500rpm at WOT and chirps into 2nd rather than short shifting at 6000rpm like it was before
When cruising at 100kph in D mode and then giving the car WOT before the reset the car would pick up the revs by about 500 for a second or so and then thump into 3rd gear. I still get the second or so delay but now it changes down to 3rd without the thump most of the time
Much happier now
I would take it back and have matic J put in the box, to many horror stories for me to think about using something other then that in the box.
Edited by T4NK
http://www.clubfrontier.org/forums/f8/truth-about-matic-j-55979/
Taken from the above link
i saw yet another post about someone being a little nervous about switching to something other than nissan fluid in their auto tranny on a 05+ frontier and i think that for alot of people here nissan atf is a touchy subject and i want to try and eliminate everyone's fears of using something other than nissan fluid or atleast give you a little more knowledge about what it is your putting into your tranny. For starters matic j, this fluid is a semi synthetic JASO 1A spec ATF actually made by "]Castrol and sold to nissan who then puts their name on it and slaps all the dire warnings on everything in their vehicles about it but the fluid is nothing more than"]Castrol Transmax J which castrol made to work in all JASO 1A spec Japanese auto trannys. JASO 1A spec is the main Japanese standard for ATF and this castrol fluid is used by nissan and subaru and is good for use in Toyota T-IV and Type T fluid requiring transmissions. This fluid has also been approved for use in applications that call for Allison C4, Dexron III, and Mercon. Castrol TransmaxJ Product Data Sheet
Some more JASO 1A spec equivalents to this fluid are Pennzoil ATF-J and IDEMITSU ATF HP which is the fluid used in Japan for our trannys
There are also plenty of Universal ATFs that can be used and what makes these so universal is that they are actually just fully synthetic ATFs that are made to JASO 1A spec which you have see above that JASO 1A spec fluids have been aproved for use in Dexron III, Mercon, Allison, and is suitable in toyota t-IV and type T along with many other trannys from many other companies. The Japanese standard of JASO 1A spec actually far exceeds the standards of most other ATFs that manufactures require for their trannys which pretty much makes anything that is made up to JASO 1A spec a universal ATF so don't let yourself get turned off when you go to amsoil's website and look at the Universal ATF and see a massive list of compatible applications, when you look at this list and wonder "how does this fluid work in all these applications" its because the Japanese standard of JASO 1A spec is far superior to fluids of any of these other applications to date. once again the best of the best comes from japan! There are however some applications that JASO 1A spec fluids do not work in and most Universal ATFs are not recommended in or have not been fully tested in like Ford Type-F, Dexron VI, and any CVT tranny
a few universal ATFs that you can breath easy about switching to now are Amsoil ATF, Motul ATF-1A, Mobile 1 Synthetic ATF, Amalie Universal Synthetic ATF to just name off a few that i can think of off the top of my head.
i hope this little write up will help shed some light on the somewhat touchy subject of ATF and maybe help any of you that are kind of on the fence make a decision about what you which to run when the time comes for tranny service on your 5 speed auto frontier. Thanks for Reading
    • Drilled the rubber out on a slow speed and it didn't catch much at all. Probably only half a dozen holes was enough to shred the rubber and it dropped off easily leaving the inner sleeve behind. Will tackle that later
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
