Hey Guys
A Jim Berry full monty has come up for sale near me pretty cheap ($600)
apparently only done 10 circuit laps
Im wondering, will the full monty be too much for around 200kw
It will be going into my stagea, i'd like something that i can launch pretty hard with as the stagea isn't the best off the line with the stock clutch
I know they are supposed to be really goo clutches but will it be too full on for a street driven car with not that much power?
Let me know if you think its worth getting or not
Cheers, Tom
  • Replies 43
Hi Tom, Depends on your driving style and if you are going to enjoy it daily.... My JB clutch is awesome to drive! Its certainly more aggressive being a button but i drive it daily quite happily :)
I've got a standard Jim berry modified clutch in my 33 its as light as the factory clutch but is a little bitey and its holding 336kw great! Never used his full monty clutch but id imagine it'd be VERY aggressive but for the price it will hold 200kw for an eternity lol
the stagea is the pull type same as 33gtr/34gtt and from what ive seen generally cost over $1k
the clamping pressure is also 4400lbs on the JB clutch for sale
pretty sure for most applications the words 'launch' and 'overkill' cant be used in the same sentence, unless you are daily-ing it through mumbai's peak hour, i would go the most expensive/military duty you/your left leg can afford
Thats a lot of clamp, mine is 4600lbs and its not likely to slip anytime soon :P They really are a good clutch and the pedal is surprisingly light!
I think the NPC was $880 or something.... What does the JB come with? Clutch, plate, bearing and flywheel?
Looks like everything bar flywheel
Offer them $500 and get your old flywheel machined :D could send the whole thing to Jim with the flywheel just so he can check its all good.....
better off getting a billet flywheel (if its still you still have the factory cast one). You don't want to introduce cracks and explode during use.
500 plus the money for a fly wheel is still a good buy
Edited by wedge_r34gtr
how much for a billet flywheel and where from?
or, seeing as its holding fine at my power level, would i be better to put money towards a nistune and tune?
If it aint broke dont fix it! Remember you would be looking to do rear main seal, flywheel and a few other bits...... Plus the labour to do!
BUT if you have a stock clutch they dont last with power long so its catch 22 :/
labour will be me and a mate probably
currently the car makes around 130awkw but will hopefully get a highflow and tune over summer and make whatever is safe on stock injectors and afm
mega catch 22
seeing as its not a ridiculously good deal i might leave it or lowball the guy, i thought $600 was a great price but im glad i asked!
Price is fair but there are other costs that surround it! My 34 clutch slipped at 200kw which was also where my injectors were maxing (Some say 220kw but not mine)
not sure if mine will be the same as 34
i'd say it would be a33 gtr clutch as thats the same box that the stagea's use
Same clutch :thumbsup:
NPC Billet Flywheels = $430 or so. Great product
I will say that the NPC clutch I have is great but the Jim Berry is slightly cheaper.
NPC is new, Jim berry is second hand.
Pro's and Con's as you already know.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
