Hey guys, I'm wanting to buy a new exhaust for my coupe. Been thinking about the Topspeed pro 1 . I want something that's just a deeper sound and a little louder either as little droning as possible :) I know I'm prob asking for to much but just don't want it overly loud. Any suggestions ???
https://www.sau.com.au/forums/topic/412313-new-exhaust-info-plz/
I've been umming and arring about the HKS rep and Magnaflow X pipe whether or not to get it or save more and get the TDX V2 + test pipes combo. I need to hear a HKS rep in person!
What's the price difference, seano?
hey where do you guys usually get the x-pipes from? ebay or?
Statik performance stocks them i'm pretty sure, for around $100 + shipping.
Massive. You can buy the TopSpeed HKS rep exhaust for $400 + $395 shipping, + $150 ish for the x pipe + whatever labour costs to fit the X pipe to the exhaust and whatever modifications need to be done to the exhaust incase it rubs (very common for it to rub against the right side diffuser and melt it) so I'd say a total of about $1300 or there abouts fitted.
Motordyne TDX V2 + ART pipes i just got a quote last night for $2175 delivered including taxes and everything. I'm not sure if i'd get a shop to fit it, i haven't heard much about the system not fitting properly so it could be a DIY job.
Went to mercury motorsports. They said I need to get a haltec otherwise I'd prob lose power from it
From such a reputable outfit it seems strange they would try feed you such b/s.
Cheers for the cost diff. So about half. I like the look of the hks rep / hks. Those looped resonators look mad. Pity you can't see them from behind the car :-/
Mat i'll just correct myself on those prices, i was quoted wrong.. the guy didn't include the ART pipes. It's actually about $2700 for the full MD TDX V2 + ART pipes shipped to your door. I'm choosing to save the money and go for the better quality stuff i have been convinced by the boys that actually own the system and absolutely love it, whereas the guys that have the HKS rep like the exhaust they did f*ck around with fitment and it's not as good quality material as the motordyne products.
They must've been talking out of their organic exhaust pipes. Did you tell them you weren't born yesterday? Wankers.
Perform a fuel relearn and your stock ecu will recalibrate to make the most of the mods within its factory tolerances.
  • 1 month later...
Greetings All,
I know that this may sound stupid,.....but I was wondering if the exhaust in the video, would work in my 2004 V35
http://www.6mt.net/forum/g35-coupe/36145-m2-performance-exhaust-review-hks-replica.html
Thanks for your time!
Yes Art it will.
Keep in mind with this system you will need the Magnaflow X pipe which heavily reduces the annoying rasp that comes with this system. More than likely you will have to adjust the hangers on the exhaust and some modifications may need to be made in order for this exhaust to not rub on the underside of the car.
Statik performance stocks them, Art join the facebook group and get in touch with Henry from Statik performance he can sort you one. TopSpeed HKS rep exhaust for $400 + $395 shipping, + $150 ish for the x pipe + whatever labour costs to fit the X pipe to the exhaust and whatever modifications need to be done to the exhaust incase it rubs (very common for it to rub against the right side diffuser and melt it) so I'd say a total of about $1300 or there abouts fitted. I have also heard that the system in some places may touch the underside of the car causing it to rattle which is very annoying so make sure it's professionally fitted. ALSO make sure you buy OEM Nissan gaskets, you will need a total of 8. DO NOT use the gaskets that come with the system as they leak.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
